You have exceeded the time limit!
doswald
hi battye, as usual its me again, your fan :D
i have this problem after upgrading from 1.2.0 -> 1.3.3 the problem seems in the time since i set to 10 (encircled in image below) when playing the quiz the error "You have exceeded the time limit!" appears even i'm faster enough to take the quiz.
may i add also this question, what is in the rectangle highlighted? what is that Bot for?
again, my apologize for being like this (i'm just a big fan of yours very likely to use your great MOD)
Try setting the time limits to 100 and see if that helps, if it doesn't we have a problem!
doswald
battye wrote:Try setting the time limits to 100 and see if that helps, if it doesn't we have a problem!
houston! we have a problem....
i changed it from 10 to 100 however same error appears
Okay. Could you please post the new version of quiz.php (in
 tags) into your reply please? Also include functions_quiz.php as well, as thta may have some code to do with the time limits as well. :)
doswald
battye wrote:Okay. Could you please post the new version of quiz.php (in code tags) into your reply please? Also include functions_quiz.php as well, as thta may have some code to do with the time limits as well. :)
thanks for the reply mate, here's my quiz.php
 *                               quiz.php
 *   begin                : Sat, May 21, 2005
 *   copyright          : (C) 2005 Battye @ CricketMX.com
 *   email                : cricketmx@hotmail.com
 *   $Id: quiz.php, v2 (May 2005) battye Exp $
 *   This program is free software; you can redistribute it and/or modify
 *   it under the terms of the GNU General Public License as published by
 *   the Free Software Foundation; either version 2 of the License, or
 *   (at your option) any later version.
$phpbb_root_path = './';
include($phpbb_root_path . 'extension.inc');
include($phpbb_root_path . 'common.'.$phpEx);
include($phpbb_root_path . 'includes/bbcode.'.$phpEx);
include($phpbb_root_path . 'includes/functions_quiz.'.$phpEx);
	$language = $board_config['default_lang'];
	if (!file_exists($phpbb_root_path . 'language/lang_' . $language . '/lang_quiz.' . $phpEx))
		$language = 'english';
	include($phpbb_root_path . 'language/lang_' . $language . '/lang_quiz.' . $phpEx);
$userdata = session_pagestart($user_ip, PAGE_QUIZ);
init_userprefs($userdata);
// Just to help users know what version of UQM they are using, I will add it here, it will be changed in every version mind you (it is commented out purposely)
// $quiz_version = '1.2.0';
	// Define mode and type
	$mode = htmlspecialchars($HTTP_GET_VARS['mode']);
	$type = htmlspecialchars($HTTP_POST_VARS['type']);
		if($type == "multiple_choice")
			$quiz_type = "multiple_choice"; // Default for 1.0.x
		if($type == "true_false")
			$quiz_type = "true_false"; // New in 1.1.x
		if($type == "input_answer")
			$quiz_type = "input_answer"; // Default for Pre 0.0.x, reapplied in 1.1.x
	if( isset($HTTP_GET_VARS[POST_CAT_URL]) ) // Let's list the quizzes in a certain category, and all that jazz
		$category_id = intval($HTTP_GET_VARS[POST_CAT_URL]);
		$password_sql = "SELECT * FROM " . QUIZ_CATEGORY_TABLE . " WHERE category_id = $category_id";
			if(!$password_result = $db->sql_query($password_sql))
			message_die(GENERAL_ERROR, 'Could not obtain category password', '', __LINE__, __FILE__, $password_sql);
			$password_row = $db->sql_fetchrow($password_result);
			if( !$userdata['session_logged_in'] )
				if( $password_row['category_permissions'] == ON || $password_row['category_permissions'] == OFF )
				message_die(GENERAL_ERROR, $lang['Quiz_registered_category_permissions_no_access']);
		if($password_row['category_password'] !== 'd41d8cd98f00b204e9800998ecf8427e' && quiz_check_category_password($category_id) != ON)
			if( isset($HTTP_POST_VARS['password']) )
				if( md5($HTTP_POST_VARS['password']) != quiz_category_password($category_id) )
					message_die(GENERAL_ERROR, $lang['Quiz_category_password_wrong']);
				$password_data = $userdata['session_quiz_categories'] . $category_id . ',';
				$update_pw_data = "UPDATE " . SESSIONS_TABLE . " SET session_quiz_categories = '" . $password_data . "' WHERE session_id = '" . $userdata['session_id'] . "'";
					if(!$db->sql_query($update_pw_data))
						message_die(GENERAL_ERROR, '', 'Could not update password list', __LINE__, __FILE__, $update_pw_data);
				redirect( append_sid("quiz.$phpEx?" . POST_CAT_URL . "=$category_id", true) );
		include($phpbb_root_path . "includes/page_header.$phpEx");
		$template->set_filenames(array("quiz_pw" => 'quiz_category_password_body.tpl'));
			$template->assign_vars( array(
			"F_FORM" => append_sid("quiz.$phpEx?" . POST_CAT_URL . "=$category_id"),
			"L_SUBMIT" => $lang['Submit'],
			"L_ENTER_PASSWORD" => $lang['Quiz_password_protect_information'],
			"L_PASSWORD" => $lang['Quiz_password_protect']));
		$template->pparse("quiz_pw");
		include($phpbb_root_path . "includes/page_tail.$phpEx");
	$page_title = $lang['Quiz_quizzes'] . ' :: ' . switch_to_category_name($category_id);
	$template->set_filenames(array("quiz_cat" => 'quiz_category_body.tpl'));
	if( isset($HTTP_POST_VARS['view_method']) )
	$method = intval($HTTP_POST_VARS['view_method']);
		if($method == 1)
			$sql_addon = "ORDER BY quiz_name ASC";
		if($method == 2)
			$sql_addon = "ORDER BY quiz_id ASC";
		if($method == 3)
			$sql_addon = "ORDER BY quiz_type ASC";
		if($method == 4)
			$sql_addon = "ORDER BY quiz_author ASC";
		$sql_addon = 'ORDER BY quiz_name ASC';
		$sql = "SELECT * FROM " . QUIZ_GENERAL_TABLE . " WHERE quiz_category = '" . $category_id . "' " . $sql_addon;
		if(!$result = $db->sql_query($sql))
			message_die(GENERAL_ERROR, '', 'Could not obtain quiz name data', __LINE__, __FILE__);
		if( $db->sql_numrows($result) == 0)
			$template->assign_block_vars("nothing_row", array(
			"L_NO_RESULTS" => sprintf($lang['Quiz_no_quizzes'], append_sid("quiz.$phpEx?mode=add"))
		while($row = $db->sql_fetchrow($result))
			$quiz_name = str_replace("\'", "''", $row['quiz_name']);
			$quiz_id = intval($row['quiz_id']);
				if( $row['quiz_author'] != -21000 )
				$quiz_author = ( $row['quiz_author'] == ANONYMOUS ) ? $lang['Guest'] : "<a href=" . append_sid("profile.$phpEx?mode=viewprofile&" . POST_USERS_URL . "=" . intval($row['quiz_author']) . "") . ">" . convert_id($row['quiz_author']) . "</a>";
				$quiz_author = $board_config['Quiz_packs_bot'];
			$quiz_type = str_replace("\'", "''", $row['quiz_type']);
			if( intval($row['quiz_plays']) != 1 )
				$quiz_plays = sprintf($lang['Quiz_number_of_plays'], $row['quiz_plays']);
			else if( intval($row['quiz_plays']) == 1 )
				$quiz_plays = $lang['Quiz_number_of_play'];
		// We need to let the users know which type of quiz it is surely.
		if($quiz_type == MULTIPLE_CHOICE)
			$ultimate_quiz_type = $lang['Quiz_type_multiple_choice'];
		if($quiz_type == TRUE_FALSE)
			$ultimate_quiz_type = $lang['Quiz_type_true_false'];
		if($quiz_type == INPUT_ANSWER)
			$ultimate_quiz_type = $lang['Quiz_type_input_answer'];
			 $template->assign_block_vars("play_row", array(
			 "U_QUIZ_LINK" => "<a href='" . append_sid("quiz.$phpEx?mode=play&" . POST_QUIZ_URL . "=" . $quiz_id . "") . "'>$quiz_name</a>",
			 "U_AUTHOR" => $quiz_author,
			 "U_TYPE" => $ultimate_quiz_type,
			 "U_PLAYS" => $quiz_plays));
	"U_QUIZZES" => switch_to_category_name($category_id),
	"U_SUBMIT_QUIZ" => "<a href='" . append_sid("quiz.$phpEx?mode=add") . "'>" . $lang['Submit_quiz'] . "</a>",
	"U_STATISTICS_LINK" => "<a href='" . append_sid("quiz_stats.$phpEx") . "'>" . $lang['Quiz_stats'] . "</a>",
	"L_VIEW_ALPHABETICAL" => $lang['Quiz_view_alphabetical'],
	"L_VIEW_TYPE" => $lang['Quiz_view_type'],
	"L_VIEW_AUTHOR" => $lang['Quiz_view_author'],
	"L_VIEW_CHRONILOGICAL" => $lang['Quiz_view_chronilogical']));
	$template->pparse("quiz_cat");
	if( $mode == 'play' || isset($HTTP_GET_VARS[POST_QUIZ_URL]) )
	quiz_permissions();
	// September 10, 2005. Newest addition. In all probability not much will be done on this tonight. I made a function though :)
	// Actually, I might CVS it.
	$quiz_id = intval($HTTP_GET_VARS[POST_QUIZ_URL]); // Intval it now. Saves doing it every time it is called up for selection (cricket-ism).
	$quiz_type = quiz_type($quiz_id);
	// Let's check the stats, if the admin wants users to be able to play each quiz, once only.
	if( quiz_check_moderative_status($userdata['user_id'], $quiz_id) != ON && $userdata['user_level'] != ADMIN )
		if( $board_config['Quiz_Play_Once'] == ON )
			$statistics_check = "SELECT * FROM " . QUIZ_STATISTICS_TABLE . " WHERE quiz_id = $quiz_id AND user_id = " . $userdata['user_id'];
			if( !$statistics_check_result = $db->sql_query($statistics_check) )
				message_die(GENERAL_ERROR, 'Could not get statistics data to check Quiz_Play_Once setting', '', __LINE__, __FILE__, $statistics_check);
			if( $db->sql_numrows($statistics_check_result) == 1 || $db->sql_numrows($statistics_check_result) > 1 )
				message_die(GENERAL_MESSAGE, $lang['Quiz_only_play_it_once']);
	// Basically, there will be three sections (no prizes for guessing). This is the first. Hopefully they are not too large.
	$sql = "SELECT * FROM " . QUIZ_GENERAL_TABLE . " WHERE quiz_id = " . $quiz_id;
			message_die(GENERAL_ERROR, '', 'Could not obtain basic quiz data', __LINE__, __FILE__);
	$general_quiz_data = $db->sql_fetchrow($result);
	// Author information
	$quiz_author_id = $general_quiz_data['quiz_author'];
	$quiz_author_name = convert_id($general_quiz_data['quiz_author']);
	$quiz_author_link = "<a href='" . append_sid("profile.$phpEx?mode=viewprofile&" . POST_USERS_URL . "=$quiz_author_id") . "'>$quiz_author_name</a>";
	// Miscellaneous
	$quiz_name = str_replace("\'", "''", $general_quiz_data['quiz_name']);
	$quiz_category = intval($general_quiz_data['quiz_category']);
	$quiz_enabled = $general_quiz_data['quiz_enabled'];
	$password_sql = "SELECT * FROM " . QUIZ_CATEGORY_TABLE . " WHERE category_id = $quiz_category";
			message_die(GENERAL_ERROR, '', 'Could not obtain category password', __LINE__, __FILE__, $password_sql);
		if( quiz_check_category_password($quiz_category) != 1 && $password_row['category_password'] !== 'd41d8cd98f00b204e9800998ecf8427e' )
			"F_FORM" => append_sid("quiz.$phpEx?mode=play&" . POST_QUIZ_URL . "=$quiz_id"),
		if($board_config['Quiz_Author_Play'] == OFF && $quiz_author_id == $userdata['user_id'])
			if( quiz_check_moderative_status($userdata['user_id'], $quiz_id) == ON )
			message_die(GENERAL_MESSAGE, $lang['Quiz_author_cannot_play'] . '<br />' . sprintf($lang['Quiz_author_cannot_play_give_edit_options'], '<a href="' . append_sid("quiz_cp.$phpEx?mode=edit&q=$quiz_id") . '">', '</a>', '<a href="' . append_sid("quiz_cp.$phpEx?mode=delete&q=$quiz_id") . '">', '</a>', '<a href="' . append_sid("quiz_cp.$phpEx?mode=move&q=$quiz_id") . '">', '</a>'));
			message_die(GENERAL_MESSAGE, $lang['Quiz_author_cannot_play']);
		$page_title = $quiz_name;
		$template->set_filenames(array("play_multiple_choice" => 'quiz_play_multiple_choice_body.tpl'));
				$mod_langs = '<br />' . $lang['Quiz_cp_play_quiz_mod'] . '<br />' . sprintf( $lang['Quiz_cp_play_quiz_mod_do'], '<a href="' . append_sid("quiz_cp.$phpEx?mode=edit&" . POST_QUIZ_URL . "=$quiz_id") . '">', '</a>', '<a href="' . append_sid("quiz_cp.$phpEx?mode=delete&" . POST_QUIZ_URL . "=$quiz_id") . '">', '</a>', '<a href="' . append_sid("quiz_cp.$phpEx?mode=move&" . POST_QUIZ_URL . "=$quiz_id") . '">', '</a>');
				$mod_langs = '';
		$select_quiz_data = "SELECT * FROM " . QUIZ_MULTIPLE_CHOICE_TABLE . " WHERE quiz_id = $quiz_id";
			if(!$result_quiz_data = $db->sql_query($select_quiz_data))
				message_die(GENERAL_ERROR, '', 'Could not obtain advanced quiz data', __LINE__, __FILE__);
				while($quiz_data = $db->sql_fetchrow($result_quiz_data))
				$quiz_question = smilies_pass(bbencode_second_pass($quiz_data['quiz_question'], ''));
				$quiz_question_id = $quiz_data['question_id'];
				$quiz_multiple_choice = array();
				$quiz_multiple_choice = explode("!*-.@.-*!", $quiz_data['quiz_alternates']);
				 "U_QUIZ_NAME" => $quiz_name,
				 "U_STATISTICS" => "<a href='" . append_sid("quiz_stats.$phpEx?" . POST_QUIZ_URL . "=$quiz_id") . "'>" . $lang['Quiz_stats'] . "</a>",
				 "F_FORM" => append_sid("quiz.$phpEx?mode=results"),
				 "F_ID" => $quiz_id,
				 "F_TYPE" => $quiz_type,
				 "F_TIME" => time(),
				 "L_MOD_LANGS" => $mod_langs,
				 "L_MULTIPLE_INFORMATION" => $lang['Quiz_multiple_information'],
				 "L_SUBMIT" => $lang['Submit_quiz']));
				 $template->assign_block_vars("quiz_row", array(
				 "U_QUESTION_ID" => $quiz_question_id,
				 "U_QUESTION" => $quiz_question,
				 "Q_ALTERNATE_ONE" => $quiz_multiple_choice[0],
				 "Q_ALTERNATE_TWO" => $quiz_multiple_choice[1],
				 "Q_ALTERNATE_THREE" => $quiz_multiple_choice[2],
				 "Q_ALTERNATE_FOUR" => $quiz_multiple_choice[3]));
		$template->pparse("play_multiple_choice");
		$template->set_filenames(array("play_input_answer" => 'quiz_play_input_answer_body.tpl'));
				$mod_langs = '';
		$select_quiz_data = "SELECT * FROM " . QUIZ_INPUT_TABLE . " WHERE quiz_id = $quiz_id";
				// I've decided not to encode the answer, it is easier to compare it to an id, such as the game_id / quiz_id partnership in 1.0.6
				 "F_ID" => $quiz_id,
				 "F_TIME" => time(),
				 "L_INPUT_INFORMATION" => $lang['Quiz_input_information'],
				 "U_QUESTION" => $quiz_question));
		$template->pparse("play_input_answer");
		$template->set_filenames(array("play_true_false" => 'quiz_play_true_false_body.tpl'));
				$mod_langs = '';
		$select_quiz_data = "SELECT * FROM " . QUIZ_TRUE_FALSE_TABLE . " WHERE quiz_id = $quiz_id";
				$quiz_answer = $quiz_data['quiz_answer'];
				 "F_ID" => $quiz_id,
				 "F_TIME" => time(),
				 "L_TRUE_FALSE_INFORMATION" => $lang['Quiz_true_false_information'],
				 "L_TRUE" => $lang['Quiz_answer_true'],
				 "L_FALSE" => $lang['Quiz_answer_false'],
				 "U_ANSWER" => md5($quiz_answer)));
		$template->pparse("play_true_false");
	if($mode == 'add')
	quiz_permissions();
	$quiz_questions_explode = explode(',', $board_config['Quiz_Min_Max_Questions']);
	if( $board_config['Quiz_Mod_Submit'] == ON && quiz_check_moderative_status($userdata['user_id'], '') != ON )
		message_die(GENERAL_MESSAGE, $lang['Quiz_only_mod_can_submit']);
		if(!$HTTP_POST_VARS['Questions_number'] && isset($quiz_type))
			message_die(GENERAL_MESSAGE, $lang['Quiz_no_number_chosen']);
		if(!isset($HTTP_POST_VARS['type']))
		$page_title = $lang['Submit_quiz'];
		$template->set_filenames(array("add_initial" => 'quiz_add_initial_body.tpl'));
			if( $quiz_questions_explode[0] == $quiz_questions_explode[1] )
			$quiz_min_max_questions_set = sprintf($lang['Quiz_min_max_set'], $quiz_questions_explode[0]);
			$quiz_default_number = '&nbsp;<b>' . intval($quiz_questions_explode[0]) . '</b><input type="hidden" name="Questions_number" value="' . intval($quiz_questions_explode[0]) . '" />';
			$quiz_min_max_questions_set = sprintf($lang['Quiz_min_max'], $quiz_questions_explode[0], $quiz_questions_explode[1]);
			$quiz_default_number = '&nbsp;<input type="text" class="post" name="Questions_number" size="5" maxlength="4" value="" />';
		$template->assign_vars(array(
			"U_DEFAULT" => $quiz_default_number,
			"F_FORM" => append_sid("quiz.$phpEx?mode=add"),
			"L_MIN_MAX" => $quiz_min_max_questions_set,
			"L_SETUP_OPTIONS" => $lang['Quiz_set_up_options'],
			"L_SELECT_NUMBER" => $lang['Quiz_select_number'],
			"L_TRUE_FALSE" => $lang['Submit_true_false_quiz'],
			"L_MULTIPLE_CHOICE" => $lang['Submit_multiple_choice_quiz'],
			"L_INPUT" => $lang['Submit_input_quiz'],
		$template->pparse("add_initial");
		if($quiz_type == 'multiple_choice')
		$page_title = $lang['Submit_multiple_choice_quiz'];
		quiz_check_question_limitations();
		$template->set_filenames(array("multiple_choice" => "quiz_add_multiple_choice_body.tpl"));
			for ( $i = 0; $i < intval($HTTP_POST_VARS['Questions_number']); $i++ )
			$template->assign_block_vars('question_number', array(
			 'U_UNIQUE' => $i));
			// To make the box..
			$category_drop_down_box = '<select name="category">';
			$category_sql = "SELECT * FROM " . QUIZ_CATEGORY_TABLE . " ORDER BY category_id ASC";
			if(!$category_result = $db->sql_query($category_sql))
			message_die(GENERAL_ERROR, '', 'Could not fetch category names!');
			while($category_row = $db->sql_fetchrow($category_result))
			$category_drop_down_box .= populate_quiz_drop_down_box($category_row['category_id'], $category_row['category_name']);
			$category_drop_down_box .= '</select>';
			"F_FORM" => append_sid("quiz.$phpEx?mode=sql"),
			"U_TOTAL" => intval($HTTP_POST_VARS['Questions_number']),
			"U_CATEGORY" => $category_drop_down_box,
			"L_INSERT_NAME" => $lang['Quiz_insert_name'],
			"L_QUESTION" => $lang['Quiz_question'],
			"L_ALTERNATE_ANSWER" => $lang['Quiz_alternate'],
		$template->pparse("multiple_choice");
		if($quiz_type == 'input_answer')
		$page_title = $lang['Submit_input_quiz'];
		$template->set_filenames(array("input" => "quiz_add_input_body.tpl"));
				 'U_UNIQUE' => $i));
			"L_CORRECT_ANSWER" => $lang['Quiz_answer_correct'],
		$template->pparse("input");
		if($quiz_type == 'true_false')
		$page_title = $lang['Submit_true_false_quiz'];
		$template->set_filenames(array("true_false" => "quiz_add_true_false_body.tpl"));
				 'U_UNIQUE' => $i));
		$template->pparse("true_false");
	if($mode == "sql")
	// Similar to that of v1.0.x but not the same
	// This is better :-)
		if($HTTP_POST_VARS['Quiz_Type'] == "Input" || $HTTP_POST_VARS['Quiz_Type'] == "True_False")
			if($HTTP_POST_VARS['Quiz_Type'] == "Input")
				$table_name = QUIZ_INPUT_TABLE; // x_quiz_input_data
				$table_name = QUIZ_TRUE_FALSE_TABLE; // x_quiz_true_false_data
			for ( $i = 0; $i < intval($HTTP_POST_VARS['Quiz_Question']); $i++ )
				$question_sql = "INSERT INTO " . $table_name . " (quiz_id, question_id, quiz_question, quiz_answer)
				VALUES ( " . next_quiz_id() . ", " . ($i + 1) . ", '" . str_replace("\'", "''", bbencode_first_pass(htmlspecialchars($HTTP_POST_VARS["Question_$i"]), '')) . "',
				'" . str_replace("\'", "''", bbencode_first_pass(htmlspecialchars($HTTP_POST_VARS["Correct_Answer_$i"]), '')) . "')";
				if( !$question_result = $db->sql_query($question_sql))
					message_die(GENERAL_ERROR, 'Could not insert question / answer data', '', __LINE__, __FILE__, $question_sql);
		if($HTTP_POST_VARS['Quiz_Type'] == "Multiple")
				// The answer isn't going to be Alternate_x_x now is it :roll:
				// Well not often anyway ;-)
				// Update: A few months later, I don't even know what the hell I was talking about. Better read the code to find out what exactly this section does eh?
				$answer = array();
				if($HTTP_POST_VARS["Correct_Answer_$i"] == "Alternate1_$i")
					$answer[$i] = bbencode_first_pass(str_replace("\'", "''", $HTTP_POST_VARS["Alternate1_$i"]), '');
				else if($HTTP_POST_VARS["Correct_Answer_$i"] == "Alternate2_$i")
					$answer[$i] = bbencode_first_pass(str_replace("\'", "''", $HTTP_POST_VARS["Alternate2_$i"]), '');
				else if($HTTP_POST_VARS["Correct_Answer_$i"] == "Alternate3_$i")
					$answer[$i] = bbencode_first_pass(str_replace("\'", "''", $HTTP_POST_VARS["Alternate3_$i"]), '');
				else if($HTTP_POST_VARS["Correct_Answer_$i"] == "Alternate4_$i")
					$answer[$i] = bbencode_first_pass(str_replace("\'", "''", $HTTP_POST_VARS["Alternate4_$i"]), '');
				// As much as I hate the following few lines, because it is awfully messy, I must say, it works beautifully
				// Basically this is the most effective way of doing it. You can use the | but that means that anyone that uses that screws up the quiz.
				// Sure the same thing can happen with !*-.@.-*! but what are the odds?
				$question_sql = "INSERT INTO " . QUIZ_MULTIPLE_CHOICE_TABLE . "
				(quiz_id, question_id, quiz_question, quiz_alternates, quiz_answer)
				'" . str_replace("\'", "''", htmlspecialchars($HTTP_POST_VARS["Alternate1_$i"])) . "!*-.@.-*!" . str_replace("\'", "''", htmlspecialchars($HTTP_POST_VARS["Alternate2_$i"])) . "!*-.@.-*!" . str_replace("\'", "''", htmlspecialchars($HTTP_POST_VARS["Alternate3_$i"])) . "!*-.@.-*!" . str_replace("\'", "''", htmlspecialchars($HTTP_POST_VARS["Alternate4_$i"])) . "',
				'" . htmlspecialchars($answer[$i]) . "')";
				if($HTTP_POST_VARS['Quiz_Type'] == "True_False")
					$ultimate_quiz_type = TRUE_FALSE;
				else if($HTTP_POST_VARS['Quiz_Type'] == "Multiple")
					$ultimate_quiz_type = MULTIPLE_CHOICE;
				else if($HTTP_POST_VARS['Quiz_Type'] == "Input")
					$ultimate_quiz_type = INPUT_ANSWER;
	$sql =  "INSERT INTO " . QUIZ_GENERAL_TABLE . " (quiz_id, quiz_name, quiz_author, quiz_category, quiz_type) VALUES (
			  '" . str_replace("\'", "''", htmlspecialchars($HTTP_POST_VARS['Quiz_Name'])) . "',
			  '" . $userdata['user_id'] . "',
			  '" . intval($HTTP_POST_VARS['category']) . "',
			  '" . $ultimate_quiz_type . "')";
			if( !$result = $db->sql_query($sql))
				message_die(GENERAL_ERROR, 'Could not insert basic quiz details', '', __LINE__, __FILE__, $sql);
				message_die(GENERAL_MESSAGE, $lang['Quiz_added_successfully']);
	if($mode == "results")
	$page_title = $lang['Quiz_score'];
	$template->set_filenames(array("quiz_result" => 'quiz_result_body.tpl'));
	$id = intval($HTTP_POST_VARS['id']);
	if( quiz_check_moderative_status($userdata['user_id'], $id) != ON && $userdata['user_level'] != ADMIN )
			$statistics_check = "SELECT * FROM " . QUIZ_STATISTICS_TABLE . " WHERE quiz_id = '$id' AND user_id = '" . $userdata['user_id'] . "'";
			$table = QUIZ_INPUT_TABLE;
		else if($type == "true_false")
			$table = QUIZ_TRUE_FALSE_TABLE;
		else if($type == "multiple_choice")
			$table = QUIZ_MULTIPLE_CHOICE_TABLE;
	$number_of_questions = number_of_questions($id, $table);
	$time_taken_to_complete_quiz = time() - intval($HTTP_POST_VARS['f_time']);
	$seconds_taken_to_complete_quiz = $time_taken_to_complete_quiz % 60;
	$minutes_taken_to_complete_quiz = ($time_taken_to_complete_quiz - $seconds_taken_to_complete_quiz) / 60;
	if( $board_config['Quiz_timeout'] != 0 )
		if( $time_taken_to_complete_quiz > ($board_config['Quiz_timeout'] * $number_of_questions) )
			message_die(GENERAL_MESSAGE, $lang['Quiz_user_exceed_timelimit']);
		for ( $i = 0; $i < $number_of_questions; $i++ )
			$sql = "SELECT quiz_question FROM " . $table . " WHERE question_id = " . ($i + 1) . " AND quiz_id = " . $id;
				message_die(GENERAL_ERROR, '', 'Could not get question', __LINE__, __FILE__);
			$row = $db->sql_fetchrow($result);
		// Fixed in 1.3.0: All errors with " and inverted commas. I think htmlspecialchars is to blame for this.
		$question = smilies_pass(bbencode_second_pass($row['quiz_question'], ''));
		$user_answer = str_replace("\'", "'", str_replace('\"', '"', $HTTP_POST_VARS['uqm' . ($i + 1)])); // Changed in 1.3.1. Added letters uqm to overcome PHP bug. Thanks to Xore (MOD Team Member) for pointing this out.
		$actual_answer = str_replace('&quot;', '"', htmlspecialchars(quiz_answer(($i + 1), $id, $table)));
			if(strtolower($user_answer) == strtolower($actual_answer))
				$correct[$i] = 1;
				$incorrect[$i] = 0;
				// The message consists of Question: Your Answer: Actual Answer
				$status = sprintf($lang['Quiz_answer_status'], $user_answer, $actual_answer);
			else if(strtolower($user_answer) != strtolower($actual_answer))
				$correct[$i] = 0;
				$incorrect[$i] = 1;
			if($board_config['Quiz_show_answers'] == ON)
				$template->assign_block_vars("answer_row", array(
				"U_STATUS" => $status,
				"U_QUESTION" => $question));
		// Get percentage
		if ( @array_sum($correct) != 0 && @array_sum($incorrect) != 0 )
			if( @array_sum($incorrect) == @array_sum($correct) )
				$percentage = '50';
				$percentage = ( @array_sum($correct) / ( @array_sum($correct) + @array_sum($incorrect) ) ) * 100;
			if( @array_sum($incorrect) == '0' )
				$percentage = '100';
			else if( @array_sum($correct) == '0' )
				$percentage = '0';
		$update_play = "UPDATE " . QUIZ_GENERAL_TABLE . " SET quiz_plays = quiz_plays + 1 WHERE quiz_id = $id";
		if( !$db->sql_query($update_play) )
			message_die(GENERAL_ERROR, 'Could not update play counter', '', __LINE__, __FILE__, $update_play);
		$percentage = number_format($percentage, 0);
		"U_CORRECT_SCORE" => sprintf($lang['Quiz_show_correct_score'], @array_sum($correct)),
		"U_INCORRECT_SCORE" => sprintf($lang['Quiz_show_incorrect_score'], @array_sum($incorrect)),
		"U_PERCENTAGE" => $percentage . '%',
		"L_TIME_TAKEN" => sprintf($lang['Quiz_user_time_taken_quiz'], $minutes_taken_to_complete_quiz, $seconds_taken_to_complete_quiz),
		"L_RETURN_INDEX" => sprintf($lang['Click_return_index'], '<a href="' . append_sid("index.$phpEx") . '">', '</a>'),
		"L_RETURN_QUIZ" => sprintf($lang['Quiz_click_return_quiz'], '<a href="' . append_sid("quiz.$phpEx") . '">', '</a>'),
		"L_ANSWERS" => $lang['Quiz_score']));
			$statistics_sql = "INSERT INTO " . QUIZ_STATISTICS_TABLE . " (stats_id, quiz_id, user_id, stats_correct, stats_incorrect, stats_percentage) VALUES ('" . quiz_new_stats_id() . "', '$id', '" . $userdata['user_id'] . "', '" . @array_sum($correct) . "', '" . @array_sum($incorrect) . "', '$percentage')";
			if(!$db->sql_query($statistics_sql))
				message_die(GENERAL_ERROR, '', 'Could not insert statistical values', __LINE__, __FILE__, $statistics_sql);
			// Let's do the cash
			if( $board_config['Quiz_CashMOD_On'] == ON )
			include($phpbb_root_path . 'includes/functions_cash.'.$phpEx);
				// Lets get the currency.. err... name?
				$get_cash_name = "SELECT cash_name FROM " . CASH_TABLE . " WHERE cash_dbfield = '" . $board_config['Quiz_Cash_Currency'] . "'";
					if( !$get_cash_result = $db->sql_query($get_cash_name) )
						message_die(GENERAL_ERROR, 'Unable to execute cash name query', '', __LINE__, __FILE__, $get_cash_name);
			$actual_cash_name = $db->sql_fetchrow($get_cash_result);
			$cash_per_correct = $board_config['Quiz_Cash_Correct'];
			$cash_per_incorrect = $board_config['Quiz_Cash_Incorrect'];
			$cash_tax = $board_config['Quiz_Cash_Tax'];
			$total_cash = ( ( @array_sum($correct) * $cash_per_correct ) - ( @array_sum($incorrect) * $cash_per_incorrect ) - ( $cash_tax ) );
			if( $total_cash > 0 || $total_cash == 0 )
			$cash_language_variable = sprintf($lang['Quiz_cash_total_result_gain'], $total_cash, $actual_cash_name['cash_name']);
				$cash_sql = "UPDATE " . USERS_TABLE . " SET " . $board_config['Quiz_Cash_Currency'] . " = " . $board_config['Quiz_Cash_Currency'] . " + " . intval($total_cash) . " WHERE user_id = " . $userdata['user_id'];
			else if( $total_cash < 0 )
			$total_cash = str_replace('-', '', $total_cash);
			$cash_language_variable = sprintf($lang['Quiz_cash_total_result_loss'], $total_cash, $actual_cash_name['cash_name']);
				$cash_sql = "UPDATE " . USERS_TABLE . " SET " . $board_config['Quiz_Cash_Currency'] . " = " . $board_config['Quiz_Cash_Currency'] . " - " . intval($total_cash) . " WHERE user_id = " . $userdata['user_id'];
				if( !$db->sql_query($cash_sql) )
					message_die(GENERAL_ERROR, 'Unable to execute cash update', '', __LINE__, __FILE__, $cash_sql);
			$template->assign_block_vars('cash_row', array());
			$template->assign_vars(array("U_CASH" => $cash_language_variable));
		$template->pparse("quiz_result");
	$page_title = $lang['Quiz_quizzes'];
	$template->set_filenames(array("quiz_index" => "quiz_index_body.tpl"));      if( !$userdata['session_logged_in'] )
         $sql_suffix = "WHERE category_permissions = 0 OR category_permissions = 1";
         $sql_suffix = '';
   $sql = "SELECT * FROM " . QUIZ_CATEGORY_TABLE . " $sql_suffix  ORDER BY category_name ASC";
		message_die(GENERAL_ERROR, '', 'Could not obtain quiz category data', __LINE__, __FILE__);
	$category_id = intval($row['category_id']);
	$category_name = str_replace("\'", "''", $row['category_name']);
	$category_description = str_replace("\'", "''", $row['category_description']);
	$category_quizzes = category_quizzes($category_id);
	"U_NAME" => "<a href='" .  append_sid("quiz.$phpEx?" . POST_CAT_URL . "=$category_id") . "'>$category_name</a>",
	"U_DESCRIPTION" => $category_description,
	"U_QUIZZES" => $category_quizzes . ' ' . $lang['Quiz_quizzes']));
	"L_QUIZZES" => ( $board_config['Quiz_timeout'] == 0 ) ? $lang['Quiz_quizzes'] : sprintf($lang['Quiz_user_time_on_index'], $board_config['Quiz_timeout']),
	// Just noticed that there are 971 line so far, can we make 1000? Yep
	$quiz_cash_correct = intval($board_config['Quiz_Cash_Correct']);
	$quiz_cash_incorrect = intval($board_config['Quiz_Cash_Incorrect']);
	$quiz_cash_tax = intval($board_config['Quiz_Cash_Tax']);
	"CASH_INFORMATION" => sprintf($lang['Quiz_cash_information'], $quiz_cash_correct, $quiz_cash_incorrect, $quiz_cash_tax)));
	// I'm now depressed, that was the first time this series I haven't labelled it L_, U_, or F_. Pfft
	$template->pparse("quiz_index");
and my functions_quiz.php
 *                               functions_quiz.php
 *   begin                : Mon, June 6, 2005
 *   $Id: functions_quiz.php, v1 (June 2005) battye Exp $
function quiz_new_stats_id()
global $db;
	$sql = "SELECT stats_id FROM " . QUIZ_STATISTICS_TABLE . " ORDER BY stats_id DESC LIMIT 1";
		message_die(GENERAL_ERROR, '', 'Could not obtain the user id', __LINE__, __FILE__, $sql);
return ($row['stats_id'] + 1);
function quiz_check_moderative_status($user_id, $quiz_id)
global $db, $board_config, $userdata;
$users = explode(',', $board_config['Quiz_Moderators']);
	for( $o = 0; $o < count($users); $o++ )
		if( intval($user_id) == intval($users[$o]) )
			$quiz_moderator = ON;
	if( $userdata['user_level'] == ADMIN )
	if( $board_config['Quiz_Author_Mod'] == ON )
		$sql = "SELECT quiz_author FROM " . QUIZ_GENERAL_TABLE . " WHERE quiz_id = '$quiz_id'";
		if( $row['user_id'] == intval($user_id) )
	if( $quiz_moderator != ON )
		$quiz_moderator = OFF;
return $quiz_moderator;
function quiz_check_question_limitations()
global $quiz_questions_explode, $lang, $HTTP_POST_VARS;
	if( $HTTP_POST_VARS['Questions_number'] > $quiz_questions_explode[1] || $HTTP_POST_VARS['Questions_number'] < $quiz_questions_explode[0] )
		message_die(GENERAL_ERROR, $lang['Quiz_min_max_exceed']);
function quiz_category_password($id)
global $db;
$sql = "SELECT category_password FROM " . QUIZ_CATEGORY_TABLE . " WHERE category_id = " . intval($id);
		message_die(GENERAL_ERROR, '', 'Could not obtain quiz category password', __LINE__, __FILE__, $sql);
return $row['category_password'];
function quiz_check_category_password($id)
global $userdata;
$session_quiz_categories = explode(",", $userdata['session_quiz_categories']);
	for ( $z = 0; $z < count($session_quiz_categories); $z++ )
		if( $session_quiz_categories[$z] == intval($id) )
			$access_accepted = ON;
return $access_accepted;
function switch_to_category_name($id)
global $db;
$sql = "SELECT category_name FROM " . QUIZ_CATEGORY_TABLE . " WHERE category_id = " . intval($id);
return $row['category_name'];
function category_quizzes($id)
global $db;
$sql = "SELECT * FROM " . QUIZ_GENERAL_TABLE . " WHERE quiz_category = " . intval($id);
return $db->sql_numrows($result);
function number_of_questions($id, $table)
global $db;
$sql = "SELECT quiz_id FROM " . $table . " WHERE quiz_id = " . intval($id);
		message_die(GENERAL_ERROR, '', 'Could not count rows', __LINE__, __FILE__);
function quiz_answer($question_id, $quiz_id, $table)
global $db;
$sql = "SELECT quiz_answer FROM " . $table . " WHERE question_id = " . intval($question_id) . " AND quiz_id = " . $quiz_id;
		message_die(GENERAL_ERROR, '', 'Could not get answer', __LINE__, __FILE__);
return $row['quiz_answer'];
function convert_id($user_id)
global $db;
$sql = "SELECT username FROM " . USERS_TABLE . " WHERE user_id = " . intval($user_id) . " LIMIT 1";
		message_die(GENERAL_ERROR, '', 'Could not find user id', __LINE__, __FILE__);
return $row['username'];
function quiz_type($quiz_id)
global $lang, $db;
	$sql = "SELECT quiz_type FROM " . QUIZ_GENERAL_TABLE . " WHERE quiz_id = " . intval($quiz_id);
		message_die(GENERAL_ERROR, '', 'Could not obtain quiz type from QUIZ_GENERAL_TABLE', __LINE__, __FILE__);
	return $row['quiz_type'];
function quiz_permissions()
global $board_config, $lang, $userdata;
	if($board_config['Quiz_Register_Play'] == ON) // If this is OFF, basically it means Guests can play quizzes.
		if(!$userdata['session_logged_in'])
			return message_die(GENERAL_MESSAGE, $lang['Quiz_must_be_registered']);
	if($board_config['Quiz_Post_Count_Play'] == ON)
		if($userdata['user_posts'] < $board_config['Quiz_Post_Requirement'])
			return message_die(GENERAL_MESSAGE, sprintf($lang['Quiz_post_requirement_not_met'], intval($board_config['Quiz_Post_Requirement'])));
function next_quiz_id()
global $db;
$sql = "SELECT quiz_id FROM " . QUIZ_GENERAL_TABLE . " ORDER BY quiz_id DESC LIMIT 1";
		message_die(GENERAL_ERROR, 'Could not find last quiz_id', '', __LINE__, __FILE__, $sql);
		$id = $row['quiz_id'] + 1;
	if(!$id)
		$id = 1;
return intval($id);
function populate_quiz_drop_down_box($category_id, $category_name)
global $lang;
$dropdown_box = '<option value=' . $category_id . '">' . $lang['Category'] . ': ' . $category_name . '</option>';
return $dropdown_box;
This is the important part:
This is in quiz.php. Could you replace that with this?
         message_die(GENERAL_MESSAGE, $lang['Quiz_user_exceed_timelimit'] . 'Time allowed: ' . ($board_config['Quiz_timeout'] * $number_of_questions) . ', time taken: ' . $time_taken_to_complete_quiz);
And try taking another quiz. It might not fix it, but it will at least give us an idea of what is going wrong.
doswald
mate thanks for the reply, here's what happened.
Okay then :shock:
See this line in quiz.php:
Replace with
$time_taken_to_complete_quiz = time() - intval($_POST['f_time']);
Does that do it?
doswald
same thing goes mate. same error appears :?
Did you overwrite all of the .tpl (template) files? It doesn't appear to be grabbing the POST data from the form. (which would explain why it said you don't have any correct answers from an earlier thread)
doswald
battye wrote:Did you overwrite all of the .tpl (template) files? It doesn't appear to be grabbing the POST data from the form. (which would explain why it said you don't have any correct answers from an earlier thread)
hi mate, yes i overwrite everything that are from the folder of 1.3.3. templates up to its admin... i'm puzzled too why these things happen...
This is in quiz.php. Could you replace:
With
         message_die(GENERAL_MESSAGE, $lang['Quiz_user_exceed_timelimit'] . 'Time allowed: ' . ($board_config['Quiz_timeout'] * $number_of_questions) . ', finish time: ' . intval($HTTP_POST_VARS['f_time']));
Let me know what happens.
doswald
hi mate, sorry for taking so long. we're in vacation last week. anyways after replacing the codes here the one that appears
"You have exceeded the time limit!Time allowed: 500, finish time: 0"
Was it a multiple choice quiz? If so, copy the file: quiz_play_multiple_choice_body.tpl into your next post. If it was an input answer, copy quiz_play_inout_answer_body.tpl etc :)
It isn't recognising the POST data at all.
doswald
battye wrote:Was it a multiple choice quiz? If so, copy the file: quiz_play_multiple_choice_body.tpl into your next post. If it was an input answer, copy quiz_play_inout_answer_body.tpl etc :)
hi, actually in all types of test type that error appears.
i will include it here the files
here's my quiz_play_multiple_choice_body.tpl
<table width="100%" border="0">
	<tr>
		<td width="50%" align="left" width="50%"><span class="genmed"><a href="{U_INDEX}" class="nav">{L_INDEX}</a></span></td>
		<td border="0" align="right" width="50%"><span class="genmed"> {U_STATISTICS} </span></td>
	</tr>
</table>
<table width="100%" cellpadding="2" cellspacing="1" border="0" class="forumline">
		<tr>
			<th colspan="2" width="100%" class="thTop" nowrap="nowrap"> {U_QUIZ_NAME} </th>
		</tr>
		<tr>
			<td class="row1" width="100%" align="center" valign="middle" height="30" colspan="2">
					{L_MULTIPLE_INFORMATION}
				</span>
			</td>
		</tr>
	<form action="{F_FORM}" method="post">
	<input type="hidden" name="id" value="{F_ID}">
	<input type="hidden" name="f_time" value="{F_TIME}">
	<input type="hidden" name="type" value="{F_TYPE}">
	<!-- BEGIN quiz_row -->
		<tr>
			<td class="row3" colspan="2" width="100%" align="center" valign="middle" height="5">
			</td>
		</tr>
		<tr>
			<td class="row1" rowspan="4" width="75%" align="center" valign="middle" height="100%">
				<span class="forumlink">
					{quiz_row.U_QUESTION}
				</span>
			</td>
			<td class="row2" width="25%" align="left" valign="middle" height="100%">
				<span class="gen">
					  <input type="radio" name="uqm{quiz_row.U_QUESTION_ID}" value="{quiz_row.Q_ALTERNATE_ONE}" /> {quiz_row.Q_ALTERNATE_ONE}
				</span>
			</td>
		</tr>
		<tr>
				<span class="gen">
					  <input type="radio" name="uqm{quiz_row.U_QUESTION_ID}" value="{quiz_row.Q_ALTERNATE_TWO}" /> {quiz_row.Q_ALTERNATE_TWO}
				</span>
			</td>
		</tr>
		<tr>
				<span class="gen">
					  <input type="radio" name="uqm{quiz_row.U_QUESTION_ID}" value="{quiz_row.Q_ALTERNATE_THREE}" /> {quiz_row.Q_ALTERNATE_THREE}
				</span>
			</td>
		</tr>
		<tr>
				<span class="gen">
					  <input type="radio" name="uqm{quiz_row.U_QUESTION_ID}" value="{quiz_row.Q_ALTERNATE_FOUR}" /> {quiz_row.Q_ALTERNATE_FOUR}
				</span>
			</td>
		</tr>
	<!-- END quiz_row -->
		<tr>
			<th colspan="3" class="catBottom" align="center" height="28">
				<input class="liteoption" type="submit" value="{L_SUBMIT}" />
			</th>
		</tr>
	</form>
</table>
	<tr>
		<td border="0"><span class="genmed"> {L_MOD_LANGS} </span></td>
	</tr>
</table>
<br />
<table width="100%" align="center" border="0">
	<tr>
		<td border="0" align="center">
			<span class="genmed"> <a href="http://www.cmxmods.net/quiz.php">Ultimate Quiz MOD</a> © <a href="http://www.online-scrabble.com">battye</a> 2004, 2005, 2006.
			</span>
		</td>
	</tr>
</table>
my quiz_play_input_answer_body.tpl
	<tr>
	</tr>
</table>
		<tr>
		</tr>
		<tr>
			<td class="row1" width="100%" align="center" valign="middle" height="100%" colspan="2">
					{L_INPUT_INFORMATION}
				</span>
			</td>
		</tr>
		<tr>
			</td>
		</tr>
		<tr>
			<td class="row1" width="50%" align="center" valign="middle" height="100%">
				</span>
			</td>
			<td class="row2" width="50%" align="center" valign="middle" height="100%">
				<span class="gen">
					<input type="text" name="uqm{quiz_row.U_QUESTION_ID}" size="25">
				</span>
			</td>
		</tr>
		<tr>
			</th>
		</tr>
	</form>
</table>
	<tr>
	</tr>
</table>
<br />
	<tr>
			</span>
		</td>
	</tr>
</table>
and my quiz_play_true_false_body.tpl
	<tr>
	</tr>
</table>
		<tr>
		</tr>
		<tr>
				</span>
			</td>
		</tr>
		<tr>
			</td>
		</tr>
		<tr>
				</span>
			</td>
				<span class="gen">
				</span>
			</td>
		</tr>
		<tr>
			</th>
		</tr>
	</form>
</table>
	<tr>
	</tr>
</table>
<br />
	<tr>
			</span>
		</td>
	</tr>
</table>
