Decrapifying Your PC
PC Decrapifier 1.8.6
Available from Pcdecrapifier.com and Download.com, this 513.49K free file for Windows,
is a trial version, designed to help remove unwanted software from your computer.
The PC Decrapifier is a program designed to remove or uninstall a specific list unwanted software in an unattended fashion. It can be used to clean off most of the annoying software that is typically shipped with newer PCs.
http://pcdecrapifier.com/
The PC Decrapifier is designed to remove a specific list unwanted software in an unattended fashion. Before running, the user may select exactly what software should be removed. Currently, it is targeted for use on The PC Decrapifier is a program designed to remove or uninstall a specific list unwanted software in an unattended fashion. It can be used to clean off most of the annoying software that is typically shipped with newer PCs.
Version 1.8.6 features ability to check for a more recent version of the PC Decrapifier.
http://www.download.com/3000-2096_4-10755678.html
Top removed item
Reset IE Home and Search Pages
