RoboMx : New Client (Alpha Build )
This is a program to replace nushi that bender is working on he intends to intergrate it into bendmx . It looks exciting..this release is a working client but needs the bugs ironed out so dont rush into it expecting a polished product...thanx (although i think you will all be impressed) :D
http://mxcontrol.sf.net/nightly/RoboMX_May11th.zip
Also bender updates this project frequently, previous releases were on the 5th,7th ,8th ,9th...so look for a new link (this is on his forum only not on the main mxcontol site ). enjoy :D . big thanks to bender 8)
http://mxcontrol.sourceforge.net/ (for bendmx/metis bot )
http://mxcontrol.sourceforge.net/module ... =index&c=5 (for robomx news)
It's pretty good :D
A new link for the latest release
http://mxcontrol.sf.net/nightly/RoboMX_May14th.zip
I think its looking good ...obviously the proof of it is in its popularity
still not finished though..bender must work on this night and day.. :D
I'm liking it more and more, it rocks :D
Another Update is available...
http://mxcontrol.sf.net/nightly/RoboMX_May16th.exe
Also the source code is avialable with a plugin software developement kit (SDK) from the following
http://mxcontrol.sf.net/nightly/RoboMX_May16th_src.zip
nice one Bender 8)
The Suns Still Shining on Benders creation 8) . nice one bender :D
RoboMx can be downloaded from here.
http://mxcontrol.sf.net/nightly/RoboMX_May23rd.exe
The source code can also be downloaded from here.
http://mxcontrol.sf.net/nightly/RoboMX_May23rd_src.zip
(remember to check the thread for the latest update ).
New release, although bender is working over time on a major reworking. At the moment he has had to set the emoticons to 8 bit only .
But.... many problems fixed and featuring support for many background
formats now :D
http://mxcontrol.sf.net/nightly/RoboMX_June6th.exe
This is not a proper release so the source code may well be unobtainable,
( there is a way to get it but its complicated, :? )
Thanx again bender 8)
Bender has made a huge name for himself, I can't believe he's a member on this forum! :D
Just a quick update on the state of the program.
Bender is trying to fix a few issues with the program that may require win98/me support to be removed making the program XP/win2k
compatible only , so if you havent got a copy get it now !
Another issue is the dual entry problem that RCMS suffers from :(
bender has decided that he is not going to help fix this problem using his RoboMx code (It is an RCMS problem not Benders, as its a compatability issue ) , so I think RCMS users are going to be left vunerable to another series of attacks...
Ladyluck is smiling on us .. Bender has said that he will be keeping the
support for win9x in place for a while at least.. I,m glad he changed his mind on that. :D
What OS do you use?
I use An old trick Battye :D , one that has saved me many times from computer viruses , I have my drive partitioned for windows 98se and XP pro also I have another drive connected as well also running XP , should a worm or a virus hit one ,I switch to the other and am up and running in about 2 minutes, then I can clean the afflicted drive easily with my anti virus program. This does mean a bit of duplication but its worth it to me in saved down time on the chat room. :P
Obviously this also means I can use the old and the new programs of my choice. :)
Oops I nearly forgot ! The Metis bot has now been ported to the RoboMx program get it from here http://mxcontrol.sf.net/nightly/Metis.zip
Put Metis.rEx to your RoboMx\Add-Ons folder and move your Metis configuration files to that folder. Start RoboMX and then you should be able to operate it as in previous versions, although as this is not the finished code expect a few minor hitches ...its looking better 8)
Finally, I have been waiting for this :D :D :D
