Hi! I was wondering if anyone can tell me where I can download the Ultimiate Quiz Mod version 0.6.1? I checked out phpbb, but none of the downloads are working there!
I want to install the quiz mod on my forum which uses CH...
Thanks in advance!
Nicole
Download Older version?
Hi
You don't want 0.6.1, that is so old and out of date it's not funny. (~3 years give or take)
Download v1.3, it is the newest, and the best. It can be obtained from http://www.cmxmods.net/quiz.php
There is no reason why it shouldn't work with CH installed, but if you run into any problems let me know.
I downloaded that version a few days ago, but there were a few lines of code that I wasn't able to find - I'm not anywhere near skilled enough to figure out how to make it work on my own! But I read somewhere that that older version was compatible with CH - so decided to take the safer route!
There were only two places that I had trouble finding the code, and both had to do with case PAGE_FAQ.... Below are the two sections that I wasn't able to find. I am using CH 2.1.6 on PHPBB 2.0.22
I could not find the following code in admin\index.php
I could not find the following code in viewonline.php
#-----[ FIND ]-----------------------------
case PAGE_FAQ:
$location = $lang['Viewing_FAQ'];
$location_url = "index.$phpEx?pane=right";
break;
case PAGE_FAQ:
$location_url = "faq.$phpEx";
break;
Those edits are not vital. All that does is add a "Viewing Quiz" line to the who is online area, to show when a user is viewing a quiz.
But this is not vital to the MOD's functionality, so you may leave that out
Well that is good news! I went ahead and changed/copied all of the files, I'm still getting an error though -- Did I mess up somewhere?
Could not obtain quiz category data
An Error Occurred
DEBUG MODE
SQL Error: 1146 Table 'cwdb.phpbb_quiz_categories' doesn't exist
Line : 1017
File : quiz.php
An Error Occurred
DEBUG MODE
Line : 1017
File : quiz.php
Sounds like you didn't run quiz_install.php
I ran the quiz install, and everything appeared to be working! I created 2 'test" quizzes, which seemed to go over well. But, as soon as I created a quiz, I didn't receive any confirmation - just a blank screen.
Also, when going back and attempting to take one of the quizzes, i'm getting a blank screen...
you can test it out on my forum if you'd like to have a look:
http://www.corpswives.com
Log-in: testing
Password: testing
Thank you for taking the time to answer my questions!
Have all of the .tpl files been uploaded to the templates/*/ directory?
If so, what version of PHP (not the phpBB forum version) are you running? (if unsure, it's usually listed in cPanel)
Do you have cPanel?
Usually this can be accessed by going to http://www.site.com/cpanel (replacing the "site.com" with your actual/real domain name)
