Install errors.
I'm running php 2.0.18 and was installing Mod 1.2.0
After doing all the changes I uploaded all files...when I ran the quiz_install i get this.
What am I missing?
Thanks in advance
below code was in Red
- Pete
Ultimate Quiz MOD v1.2 Series
The script is now going to alter your forum database so the Ultimate Quiz MOD can function!
Any queries which are shown in green were executed successfully, those in red however, encountered a problem. It is absolutely vital that you have made all code changes already, and uploaded all quiz files to their respective locations.
CREATE TABLE phpbb_quiz ( `quiz_id` int(10) NOT NULL default '0', `quiz_name` varchar(200) NOT NULL default '', `quiz_author` int(10) NOT NULL default '0', `quiz_enabled` int(1) NOT NULL default '0', `quiz_category` int(5) NOT NULL default '0', `quiz_type` varchar(20) NOT NULL default '0', `quiz_plays` int(5) NOT NULL default '0');
CREATE TABLE phpbb_quiz_categories ( `category_id` int(5) NOT NULL default '0', `category_password` VARCHAR( 100 ) NOT NULL default '', `category_name` varchar(140) NOT NULL default '', `category_permissions` int(1) NOT NULL default '0', `category_description` varchar(255) NOT NULL default '');
CREATE TABLE phpbb_quiz_statistics ( `stats_id` int(5) NOT NULL default '', `quiz_id` int(10) NOT NULL default '', `user_id` int(10) NOT NULL default '', `stats_correct` INT(5) NOT NULL default '0', `stats_incorrect` INT(5) NOT NULL default '0', `stats_percentage` INT(3) NOT NULL default '0');
CREATE TABLE phpbb_quiz_multiple_choice_data ( `quiz_id` int(10) NOT NULL default '0', `question_id` int(10) NOT NULL default '0', `quiz_question` text NOT NULL, `quiz_alternates` text NOT NULL, `quiz_answer` text NOT NULL);
CREATE TABLE phpbb_quiz_true_false_data ( `quiz_id` int(10) NOT NULL default '0', `question_id` int(10) NOT NULL default '0', `quiz_question` text NOT NULL, `quiz_answer` text NOT NULL);
CREATE TABLE phpbb_quiz_input_data ( `quiz_id` int(10) NOT NULL default '0', `question_id` int(10) NOT NULL default '0', `quiz_question` text NOT NULL, `quiz_answer` text NOT NULL)
ALTER TABLE phpbb_sessions ADD `session_quiz_categories` VARCHAR( 255 ) NOT NULL;
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_show_answers', '1')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Register_Play', '1')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Post_Count_Play', '1')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Post_Requirement', '1')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Play_Once', '1')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Author_Play', '1')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Min_Max_Questions', '5,10')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Author_Mod', '1')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Banned', '')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Moderators', '')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Stats_Display', '10')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Mod_Submit', '1')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Cash_Currency', 'user_points')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Cash_Incorrect', '1')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Cash_Correct', '1')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Cash_Tax', '2')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_CashMOD_On', '1')
Installation is complete, however, some errors were encountered. It is suggested that you rectify these problems before attempting to use the Ultimate Quiz MOD!When I go into quiz in my admin sidebar I get
Could not get category data
DEBUG MODE
SQL Error : 1146 Table 'phpbb_2.phpbb_quiz_categories' doesn't exist
SELECT * FROM phpbb_quiz_categories
Line : 338
File : admin_quiz.php
