I have followed the file moves and changes with no problems, but when I go to run the quiz_install.php file I get a blank screen. The only change from the install instructions was I use a different template and the quiz link is represented differntly. Other than that everything is the same.
I tried to install quiz 1.3.3 on phpBB 2.0.21 with no other mods installed. I see the link in ACP and the link on the main page of the forum.
Any ideas?
Thanks in advance.
quiz_install.php shows blank screen
HarleyDude
I found the problem. It was either permissions or ownership. I think it was the permissions on the quiz_install.php file. I changed the permissions and changed the ownership to 755 and it worked.
