http://www.battye.jmstacey.net/index2.htm is Igloo
http://www.battye.jmstacey.net/index3.html is Appalachia
http://www.battye.jmstacey.net/ is SubSilver
HTML usergroup
I just edited it, its http://www.battye.jmstacey.net/index3.html
That's great
In the bit where it says
You put
That would of course be for SubSilver
href="viewforum.php?f=2"Code: Select all
href="http://www.battye.jmstacey.net"CricketMX.com in 2022: Still the home of bat's, rat's and other farmyard animals!
I am lost at this point. In the code it says:
There is no href. I am
! I'll have to play around with it tonight. Going crazy because I don't understand html very much.
Action = "viewforum.php"In mine, I don't see an "action" bit
Oh wow, I can edit your posts. I didn't notice that, I went to hit quote but hit edit instead. Pretty cool being a moderator. Sorry for playing around.
I have no idea what's happening, explorer won't let me view the source of the file you sent me
Do you mind resending that txt file, but zipping it up first?
I think I can then modify it to do it properly
Just a quick update: progress is going well
Hmm, for some reason it keeps wanting to send me to ?index=2.htm instead of just index2.htm
The worst part is, there is not one single ? in the whole document
Well, I'm getting it to link to http://www.battye.jmstacey.net/*****, the only problem is it wants to add ? and = in as well which is screwing everything up. I've tried renaming the themes to the new ?index=2.htm format, but anything with ? in front will just redirect you to the real homepage. Is making sense?
