I have also been playing a bit with it but no luck yet
HTML usergroup
I added myself just then, I thought it was polite to ask the the group moderator first
Are you talking about the new theme SubBlack, or the new folder icons in Appalachia?
I know, but I need to put a black background behind the logo first
The new post icons should be circular, instead they're oval.. I don't get it
I was just playing around, I've come across something else we could use for our drop down menu
I think there might be something in this:
But maybe changed to:
What do you think?
<link rel="chapter forum" href="viewforum.php?f=2" title="Updates" />Code: Select all
<link rel="chapter forum" href="web address of theme" title="title of theme" />CricketMX.com in 2022: Still the home of bat's, rat's and other farmyard animals!
You see at the bottom of this page?
Jump To:
Well, that's code from that, understand? Because that's a drop down menu taking you to a different page
Jump To:
Exactly, however, I don't know what the opening tag for that small code is... I can't get view source off these pages, can you?
I can add that to my themes, all I need is the locations of the theme pages so they will actually link up. That way I can test it at home instead of sending it to you, you editing the links and then testing it.
