test
Guest
I cleaned it up just a little. This code will produce the url you need to access, after you swap out the username and password.
I use the curl program for this, but wget, lynx, w3m, and who knows what else would work as well.
curl `CmxUptime.sh` > /dev/null 2>&1
You could set this as an entry in cron to have it run whenever.
47 * * * * /usr/bin/curl `/home/nesman/bin/CmxUptime.sh` > /dev/null 2>&1
#!/bin/bash
#File name: CmxUptime.sh
UPSECONDS="`cut -f1 -d'.' /proc/uptime`"
let UPDAYS="${UPSECONDS} / 86400"
let UPHOURS="(${UPSECONDS} % 86400) / 3600"
let UPMINUTES="((${UPSECONDS} % 86400) % 3600) / 60"
echo -n "uptime.cricketmx.com/upload.php?"
echo -n "username=nesman64&password=passvord"
if [ "${UPDAYS}" -ne "0" ];
then
echo -n "&days=${UPDAYS}"
fi
if [ "${UPHOURS}" -ne "0" ];
then
echo -n "&hours=${UPHOURS}"
fi
echo "&minutes=${UPMINUTES}"
WillowWatcher82
- Frequent Poster
Good thread. I keep a simple log of every bet — stake, odds, result — and reviewing it weekly catches my leaks faster than any tip sheet. <a href="https://play99exch.me/">play99exch id</a> is one of the reference points I use when comparing prices.
