New RCMS 6.3 Release
A new version of RCMS is available from http://2sen.dip.jp/2sene/ 8)
this version has had all the previous "backdoors" removed and contains
anti RTF code also, this version also seems more stable if you attempt to download ..unlike the 6.2 version. Vladd has removed his version of RCMS and this version is now the only one commonly available, although if you look around ver 5.0b can still be found. :D . Thanks go out once again to the program creator "nushi matari" a pseudonym i,m told. :lol:
Vladd44
actually i didnt remove 5.xb. its still available for download.
I just lowered it in the list.
I hope you accept my apologies for my mistake vladd :oops:. You do indeed still have the 5.0b modified version available for download , i was referring to the original being available just no sure where , and as a reminder for those who may need some useful tools for winmx , look no further
http://www.vladd44.com/winmxtools.htm 8)
Vladd44
eventually i will get around to hosting all the versions of rcms i have in one location.
maybe even source code for 3.8.
The avalanche has already started, it is to late for the pebbles to vote. - Kosh
I,m not happy to post this but a possible flaw is present in the 6.3 release, it is being investigated presently, hopefully it will prove benign, obviously i will not post details of it unless a fix/patch or modification becomes available, (if it is actually needed). I am using it myself and i feel its a better release than some of its predecessors, I hope this is just a case of a bit of rushing on behalf of "nushi". Fingers and toes are crossed on this.
Another small problem that is occuring is with small file being downloaded. The download will fail with the error report "segment error " this seems to affect 6.3 users only, luckily the cure is simply to rebrowse and start downloading again from your source. ( programs above 500kb seem ok ).
For those reading this thread i strongly suggest getting the RTF patch
mentioned in the index list (ver 5 RTF ) this covers more holes than just the RTF one and it also stops some other naughty operations with nushichat and variants. I have heard of problems with bend and this program ... anyone with any specifics please post .... :?
I think Rock has :)
Congrats on the second star mate! :D
I,ll grill him battye :lol: . I never even noticed the star :?
Thanx !
Rock
Yes i have had problems with BendMX lately ... For example when u send PM's, everytime you hit enter , squares came up instead of going to the next line and also receiving messages, you couldnt read the whole message in the PM window ...
Also a reoccuring problem was with typing in normal chat window at the end of each sentence ASCII characters would appear ( This Is Puzzling as it Has Been Happening with the old patch too).
Since i got the patch its fixed the squares ( instead of going to the next line) when you press Enter
Also has fixed receiving PM messages
But hasnt fixed my ASCII character problem at the end of sentence
I have reinstalled a fresh copy of BendMX several times and got fresh version off the site and installed a fresh WinMX each time i have done so ... And it still persists on write the ASCII characters ... But the Patch Does Work With Just WinMX
U can get the NEW Patch at : http://trueprogramming.tk
Rock
Thanks rock, 8) I hope that info reaches the right ears
( The nice people at trueprogramming or Mx controls ). :wink:
