This time i had more success, there are however one or two problems.
I can add quiz's and categories this time around (which is more than last time), but i get an error once i submit my answers after taking the quiz.
This is the error message i encounter.
An Error Occurred
DEBUG MODE
SQL Error : 1064 You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'WHERE quiz_id = '1'' at line 1
Line : 165
File : functions_quiz.phpI took a look in the database and the line was already present in phpbb_config, it did however have the value 'on' rather than 1 as the error lead me to assume was needed. I altered that accordingly, not sure if that was right or not though. haha
If you have any idea about those things please let me know, i am sure the quiz mod would be warmly welcomed by my members.
