somme troubles in mind with UQM
jpd
hi
I 've installed teh last release of UQM on my board which is: phpBB 2.0.17 + CH2.05.
It seems to work as long as the ACP is set like this: admin validation of quizz set to "off"
If I set it to "on" and I try to validate any quizzan error message is occuring
"Template->make_filename(): Error - file admin_validate_body.tpl does not exist".
I'm perfectly shure to have uploaded this template at the right place (I did three times)
So What should I do right now?. I'm Lost (and not only in translation)
How many templates do you use? And if possible, can you name them?
jpd
I only used the most classical one: subSilver
Are you still using this release? I thought you are using 1.1.0 now?
jpd
yes but, I only tried because as you can see with my last posts I 'm not more lucky with the last release!
Ok, well, it looks like the file admin_validate_body.tpl is missing. In the 1.0.6 download, go to the templates folder, and upload admin_validate_body.tpl to templates/subSilver on your forum :)
jpd
battye wrote:Ok, well, it looks like the file admin_validate_body.tpl is missing. In the 1.0.6 download, go to the templates folder, and upload admin_validate_body.tpl to templates/subSilver on your forum :)
`when I said previously , "yes", I meant "yes I'm right now trying to use use the relaease number 1.10.
Do I still have to upload the file admin_validat_body.tpl?
