Hi
Installed the quiz. Very nice thank you. (waiting the next update)
When you go into the quiz along the top is "Click To Play Random Quiz!" I would like to add a link there back to the forum index as there doesn't seem to be one at present.
Is this possible and what would I need to edit
Add a link back to forum from quiz
hi, glad you like the mod, the next update is coming along well, so far i have finished the playing and adding quiz modules, and in my opinion, they are fantastic. leagues ahead of the current system
k, in quiz_cat_body.tpl (in your templates/Whatever-template-you-use/ directory) find the following:
replace that with
i can help you change the order or wording as well if you need it too
<a href='{RANDY_LINK}'>{RANDY}</a><br /></span></td>Code: Select all
<a href='{RANDY_LINK}'>{RANDY}</a> | <a href='index.php'>Go to the Forum Index</a><br /></span></td>CricketMX.com in 2022: Still the home of bat's, rat's and other farmyard animals!
