I installed the and ran ult_database.php it showed all installed ok but i get this error in the admin area when i click to add a catagorie
ANY IDEAS?
Could not perform category task
DEBUG MODE
SQL Error : 1146 Table 'date_base.QUIZ_CAT_TABLE' doesn't exist
SQL Error on install
Have you made the alterations to constants.php?
dwightstone
- Greenhorn
Maybe that is it BUT i dont think I am going to install it as when i did i messed up the site So I may try but i am not surebattye wrote:Have you made the alterations to constants.php?
If you don't apply all of the changes in the install file, then it won't work.
This apply's to all MOD's though
