DVD's
k79890
Frequent Poster
Frequent Poster
How do you burn non-DVD format files through nero, so that they play on a DVD player.
"I'm sorry Jack, but tell jacob to stop. because when i die i can ascend."
"you think it will be ok Daniel."
"I don't know jack, but i think it is best"
Grinch
You will most likely have to convert them to DVD format or if your DVD player will play VCD's, convert them to VCD.
Check out http://www.videohelp.org for help on converting file formats.
I personally use Cucusoft avi to DVD converter. Not free but it can be :D
KrazyKid
If you're just doing pictures and videos, using Nero, go to Pictures/Videos, and then click Video CD. You don't get to create a fancy menu or anything though.
KrazyKid
My new site is up!
thatothersite.net
Nero needs an mpeg plugin. Once you've got that you can let Nero convert avi to mpeg all on its own. That'll let you make VCD, SVCD and DVD formats... assuming you also have the necessary hardware.
k79890
Frequent Poster
Frequent Poster
where can i get the plugin
Try this: link ;)
If that doesn't work, search for "nero plugin" on any p2p system or torrent site.
