installation issues
mynfel
I actually have most of the installation working, but two things appear to be incorrect. One is in the overall_header.tpl - with the lines:
<span class="mainmenu">&nbsp; &nbsp;<a href="{U_QUIZ}" class="mainmenu"><img src="templates/thorns/images/icon_mini_quiz.gif" width="12" height="13" border="0" alt="{L_QUIZ}" hspace="3" />{L_QUIZ}</a></span>
With this code, the link to Quiz shows up in the header - but the link doesn't go anywhere - just back to the index. I know the link exists because if I type in in manually (i.e. /thorns/quiz.php it works just fine. Thoughts?
Also when I go to actually click on a quiz and it starts up - underneath the title of the quiz is a box with an x - clicking on the box toggles the statistics bar. What graphic is supposed to be here?
I have several other mods installed, including the categories mod. Thanks.
Have you changed the setting to Categories Hierachy installed? (Information on how to do this is in the install file).
As for the x issue, it sounds like you haven't uploaded the image files :)
The link issue was resolved in 1.0.6 :)
Jazz(FU)
I also installed 1.0.3 and have the ame problem with the link simply repeating the current page. I also have the latest version of the Cat Heirarchy mod installed on phpbb2.0.15
And yes, i set $categories_hierachy_on to "On" as instructed in the install file.
I'm pretty sure I fixed that in 1.0.4 or 1.0.5, seeing the latest version is 1.0.6, I would suggest updating to it as that should fix the problem. Let me know how you go, thanks :)
Jazz(FU)
I am using 1.0.6
Did you reapply the changes to page_header.php?
Jazz(FU)
reapply? These changes are the only ones i see.
#-----[ OPEN ]------------------------------------------
includes/page_header.php
#-----[ FIND ]------------------------------------------
	else
		// We have a nested array, used for items like <link rel='chapter'> that can occur more than once.
		while( list(,$nested_array) = each($nav_array) )
			$nav_links_html .= sprintf($nav_link_proto, $nav_item, $nested_array['url'], $nested_array['title']);
#-----[ AFTER, ADD ]------------------------------------------
	// Check if there is only one quiz category
	if($board_config['quiz_one_category'] == "On")
	$category_number = '1'; // Change this if for some reason you do not use id '1' as your only category
	$quizlink = append_sid('quiz.' . $phpEx . '?category=' . intval($category_number) . '');
	else if($board_config['quiz_one_category'] == "Off")
	$quizlink = append_sid("quiz.$phpEx");
	'L_WHOSONLINE_MOD' => sprintf($lang['Mod_online_color'], '<span style="color:#' . $theme['fontcolor2'] . '">', '</span>'),
	'L_QUIZ' => $lang['L_quiz'],
	'U_QUIZ' => $quizlink,
This line is very important, make sure it is exactly as follows:
Jazz(FU)
battye wrote:This line is very important, make sure it is exactly as follows:
exactly.
Can you please post a link to your site? Thanks :)
Jazz(FU)
http://www.bornforthegame.com/forums/
If i type in http://www.bornforthegame.com/forums/quiz.php you get the quiz page, but the link in the header doesnt work.
Jazz(FU)
Any ideas?
Have you got the one category setting on by any chance?
Jazz(FU)
No that setting was not changed. The defeault is in place.
Hmm, can you post the quiz section of overall_header.tpl please (the one you are using). I'm wondering if something hard-coded is there.
