Not sure where to post this but HOLY CRAP
It's only 7200 RPM with an 8 Mb cache,pretty standard. But it's case is small and can be rack mounted has FireWire 800, FireWire 400, iLink/DV, Hi-Speed USB 2.0 or USB 1.1, so you can daisy chain uummm lets say 3 or 4 together
You wouldn't likely be transfering one terabyte all at once. And over USB 1.1, it would be unthinkably slow. But since USB 2 is like 40 times faster I think, that'd be decent.
Ouch. Set that to run when you are about to leave for the weekend.Rat wrote:Well obviously you wouldn't want to transfer the whole lot at once.... unless you worked for NASA or something... but still.. imagine doing a format or defrag.
