winmx trouble
Locked
nunyadamnbidness
OK here it goes.
I can d/l from mx but very few can d/l from me.
cable connection.
sygate firewall tweaked to allow the proper ports.
on a primary connection to winmx
the users who can download from me are on all diffrent connections 56k T1 cable etc. so I don't think thats an issue.
They will sit until the connection times out, I have adjusted all the timeouts to give them plenty of time to connect.
I don't use mxmoni.
transfer rate is maxed out
I have also tried using a secondary connection and moving shared files to a different drive.
All of this happened just after I down loaded v3.53 and I have reloaded it twice. It ran great for 2 weeks then I started hitting a lot of "dummy" files which will sometimes boot me off of winmx.
Hope thats enough info for you.
Hi Nunyadamnbidness , have you read this topic over as it seems some of the advice there is relevant to your problems.
http://forums.cricketmx.com/viewtopic.php?t=1705
(This post requires moving please to WinMx Support)
quicksilver wrote:(This post requires moving please to WinMx Support)
No it doesn't. We don't have one. It's a WinMX Discussion forum and is clearly marked with "Not a support forum, for any WinMX related questions, please post them in Support." The only problem is that this isn't the 'right' support. The thread is also there tho. Locking.
Locked
