Shareaza Network Cache Problem
It seems that at the moment the cache look up for shareaza is non functional, so follow the instructions located here (from when it happened before),
to get connected to the network.
http://forums.gnutelliums.com/showthrea ... adid=18730
To get around this issue, you can add the IP address of Gnutella2 host cache to Shareaza. When you open Shareaza, goto "View"|"Discovery"|"Add Service". Then paste in this IP address:http://66.199.183.172/cache/cache.aspx.
hit F9 i think it is for the web cache list, and you can manually query a certain web cache - or if for some reason (due to having sharaza running while not connected?) your cache list is empty then there are plenty to add to http://gcachescan.jonatkins.com/
