Its free and operates easily from your Print menu, simply create your document, select print, select Primo pdf and its done!!
http://www.primopdf.com/
Free and easy PDF creator
- ..Ñøßߥ..
If there's one thing I've learned, it's that life is one crushing defeat after another until you just wish Flanders was dead.
Hi Nobby, welcome to the peaceful retreat that is CricketMX
That looks like a good utility, I stupidly purchased an old copy of Acrobat to do the same job a while back,
Ello again,
I have now installed and tried PrimoPDF. It seems pretty good. It has the annoying habit of opening acrobat reader as soon as you save a new file. I don't need to immediately view all pdf files as I make them and can't find a way to turn that off. Still, a nice product. In the attachment (warning, size about 320KB), you'll see what it made of the CMX index page when I was looking at it just now. It seems fairly accurate, except for the lack of background colours.
- cmx.pdf
- (317.55 KiB) Downloaded 266 times
