Need some setup help
Do the ports that are set in WinMX match the ports you have mapped in your router?
And who is your ISP? Some ISP's block common P2P ports so it may be an idea to use a not so common port for WinMX.
For more information on setting up your router see http://www.portforward.com/routers.htm
