File Mismatch (004)????
pointblanke
All of a sudden I get this everytime I try to download on WINMX. How can I fix it??? The message is : file mismatch (004). Thanks!!!!
- Red XIII
- Sultan Ruler Of The Poles!
Have you already started downloading the file and want to get it going again after a crash?
If you do recieve that, you either just keep having it find sources now till a compatible match comes along, or just keep trimming off 10k from the end of the file till it successfully matches
^ (advanced users only...usually only for large movies...music loses a lot from it with even 10k gone)
HI Pointblanke , this is normally caused by a bit of the file you have being corrupt.
What you need to do is when the file is red , right click on it and select Trim 10k from file (I usually click this twice
) , and then retry to download it.
Hope that helps
(Hmm while I was typing Red was posting
Maybe I should trim him too..lol )
Hope that helps
Quality before quantity Red
pointblanke
Actually the file never gets a chance to start downloading. It connects for literally a split second and goes to file mismatch before any data is transferred.
Can you confirm that this is happening on new files , not ones you have as incomplete, and also can you try to d/l small files 50k and normal mp3,s and see if there is any change (50k is a small text type file ).
sounds like musicmatch is interfering, or some other mp3 program.
The avalanche has already started, it is to late for the pebbles to vote. - Kosh
- Freezmizer
I suspect that the cause is this also.Vladd44 wrote:sounds like musicmatch is interfering, or some other mp3 program.
If you have musicmatch jukebox installed, you will want to disable the "watch folders" option.
Hmm thanks Vladd, Freeze
Thats a new solution to add to my knowledge base
I,m one of those "use Microsoft and put up with it not working" types of people, so I would never have got to the bottom of this one
pointblanke
Disabling the watch folder on musicmatch did the trick. Thanks for your help! You guys are awesome. I never would have figured that out myself. Thanks again!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- Freezmizer
Or maybe its just the drugs kickin' in!
