you can get it from http://www.exosee.com
exosee
Hmm interesting, but it looks like a "personal server " app to me. The whole community rests on the server. (Community Server
the original can be found here
http://www.exosee.com/?w=ExoSee-CS
Feedback folks ??
Hope you all dont mind that I edited it slightly to make items more clear ,ExoSee-CS (Community Server) is a server application to create a group/community.
The application creates an ID which you would publish public-or-private in order for users to join your community. ExoSee-CS is a community-server NOT a users-server.
Once users start/contact your community, they are not connected to the CS-application unless you have a chat-room enabled. Overall, the application should be active/online for new incoming users.
The CS takes very little system-resources, and can be run on any version win32 operating system.
It's a stand-alone application not requiring any special installation, just run and start it.
To learn more how to create/setup your own network/community, see creating own network page.
Features
Create a community for a public or private use all over the world,giving your community-Id to the users you want to join your Network.
Dynamic-IP supported, allowing hosts to keep a static ID.
Usefull if you IP address is dynamic, thus you can have a static ID even if your IP address is not. The ID created depends on the host Pc,s IP address and the given name of your network.
Router/NAT support, you can set CS ports (726,728 TCP).
Auto-run at system-start option
The ability to ban users from entering your com, and an auto-ban for LAN users.
Customised welcome Create a page users will see upon com-entrance, Html tags allowed.
Chat-room feature so users can group chat and interact.
Com-Association This allows your community to associate with other communities for multi-source purposes to have big files shared as portions for fast downloads.
Feedback folks ??
