Unzip it, open the folder creat.sound and ctrl + drag all the mp3 files you want to convert (remember the more you add the longer it takes) into it. Then double click convert32.bat which will begin the conversion process, once the diologue box has disappeared, open up the sounds directory and you will see a number of rbs files, these are the converted mp3's
Then use Winzip or Winrar to compress them and send to me. You will need to send them to me on MSN because they will be too big to attach to the forum (if you do more than one)
