Battye, that's what I thought you might be doing.....cause when I tried this last time to get in, instead of an error message, it said
"It worked, you are here becuase the site you are looking for has switched to ______ ?" I forgot the weird name. and said something about secure ssl stuff.
So had you not switched to a new server?
it had a major problem before similar 2 this, and we lost most of the forum luckily battye had back up some, but alot was lost
this time he has backed up in advance so i would'nt worry 2 much, if anything does go wrong it'll be back up in a few days or less, and he is in the process of lookin @ other hosts, maybe he'll swap???
Well just remeber that it could cause the site to unaccesable for up to two days, but there is no way to avoid that. I also have my server available if you want to give it a try.
Don't count your toads until they're running around with their heads cut off.
Thanks for the offer Jc, but if we go with Canaca's hosting, we get a free domain
