Features
Loads files up to 2 GB in a couple of seconds!
Multi-document, multi-window interface. You can open as many files as you want, as well as open as many windows per file as you want.
Later you can use Copy(Cut)/Paste operations between opened files.
Autorestore feature that helps you restore opened files after system failure.
Powerful Find feature.
Drag&drop and other shell integration features.
Goto (or jump) feature that allows you to move to any absolute or relative location in the file.
Fill feature that can fill tens of Megabytes with undo support!
Full Undo support. (The only limit is your hard disk free space).
Expanding (inserting several parts) files, deleting parts of files etc. with full undo support.
If you are using Windows 95 or Windows 98 operating system Download the Windows Installer here :
http://www.hhdsoftware.com/Download/Red ... stMsiA.exe
If you are using Windows NT operating system, Download the Windows Installer here:
http://www.hhdsoftware.com/Download/Red ... stMsiW.exe
You Can Also Download The French Version Here ( For The French People out There )
http://www.toutfr.com/?p=list-661
There is a later version out as well which you could download from here:
http://www.hhdsoftware.com/Download/hexedfull.exe
