[DVD] Dvd Shrink
This is a useful utility for decrypting and copying dvd,s to the hard-drive for backup purposes. Also you can burn to disk If you have Nero burning software installed.
http://www.filemirrors.com/search.src?f ... 2setup.zip
This product is freeware.
does it reduce the size?
Sorry Battye , just in a rush to post :oops:
DVD Shrink will also burn your backup DVD, if you have installed the latest version of Nero. If you already possess alternative burning software and prefer to stick with it, then you can still use DVD Shrink. The output from DVD Shrink can be saved as files on your hard drive, which you can then burn with software of your choice. Also compression of the file is available and also removal of extra language support to save space.
Specifications:
DVD Shrink - DVD Ripping and Backup
Latest Version - 3.2.0.15
Operating System Support - Windows 9x/2000/XP
License - Freeware
Here is a how to for using the program
http://www.doom9.org/index.html?/mpg/dv ... 1-main.htm
StorbinC
Nice Guy
Nice Guy
Location: Sometimes here & sometimes there but never near
http://www.dvdshrink.org/
DVD Shrink will let you conpress the disc and remove unwanted content so it can fit on a DVD.
DVD Shrink is software to backup DVD discs. You can use this software in conjunction with DVD burning software of your choice, to make a backup copy of any DVD video disc.
DVD Shrink is free software. You should never pay for DVD Shrink.
Version 3.2.0.15 http://www.filemirrors.com/search.src?f ... 2setup.zip
sometime u feel like a nut
sometimes you don't
