PHP: How to echo (Can you hear me?)
After commenting (I'll write one about it later) one of the most useful functions is 'echo'
Basically you write a variable. Variable names must be in this format:
(Dollarsign)(Alpha-numeric characters)
So a valid variable name would be:
$vari
Invalid would be
vari
Because it is missing the dollar sign, to end the variable, you must tell PHP what it's supposed to resemble, so you could use a number:
$vari = 1
Or a word:
$vari = Hey there
Never forget to end a line of code with a semicolon!! ( ; )
If you forget, you will get an error along the lines of:
Parse Error: Parse error on line xx
So a valid line would be:
$vari = Hey There;
To start and end a section of PHP code, you must use 2 codes. To start a section:
And to end:
Now on to the echoing. Echoing is very simple, it simply prints and displays a variable or variables that you choose. You can use HTML in them. To start an echo, you write
echo
Simple, then:
echo 'Put your text in here';
OR
echo $vari;
If you're simply echoing a variable you don't need the ' & '.
An example of good code, from top to bottom:
This PHP Script wrote: <?php <<< Start PHP code
$forum_age = 8; <<< Variable
echo 'This forum has been up for '; <<< Note the space between for and '
echo $forum_age; <<< Variable, no '' needed
echo ' '; <<< Space to go after the variable
echo 'months'; <<< Just a word, need ''
echo '<br />'; <<< HTML can be used
?> <<< End PHP Code
Of course you don't include the text which I have highlighted in italic, that will just confuse PHP and throw up a parse error :P
If you want to see it without the italics:
This PHP Script wrote:<?php
$forum_age = 8;
echo $forum_age;
echo ' ';
echo 'months';
echo '<br />';
The final product would be:
This forum has been up for 8 months
Used in this example, it's not as effective as HTML but when you start getting SQL (Database) queries they become very useful :D
StorbinC
Nice Guy
Nice Guy
Location: Sometimes here & sometimes there but never near
ok i copied the text above to see if it really works, I saw this raw code on another of Batt's posts and was wondering what was up with it.
I guess maybe he has it working now???
$forum_age = 8;
echo $forum_age;
echo ' ';
echo 'months';
echo '<br />';
StorbinC
Nice Guy
Nice Guy
ok i guess not
sometime u feel like a nut
sometimes you don't
Hmm interesting Battye, I hope to see more input from other contributors as well to show style differences in the layout .
Its a good start to the month ,well done 8) .
StorbinC wrote:ok i copied the text above to see if it really works, I saw this raw code on another of Batt's posts and was wondering what was up with it.
$forum_age = 8;
echo $forum_age;
echo ' ';
echo 'months';
echo '<br />';
You need to upload it to a PHP enabled server for it to work, example @ http://www.cricketmx.com/testforum/dontuseme.php :wink:
btw i just wrote it today, so u cant have seen it before :?
Just to add, php is like html as in you can write you code in notepad or wordpad. When your done with the code you would save it as:
echo.php
Upload it to your php enabled server and then access the page.
www.yourdomain.com/echo.php
