Nushichat
This is one of the classic programs on MX that seems to have been over looked because most ppl who have been around for a while take it for granted :)
It is a stand alone program for using the WinMx chatrooms. You can,t share files with it or host a room , ( you can admin with it though :D ). This is english version 2.5.
http://2sen.dip.jp/arcs/NushiChat25e.zip
Big thanx go out to the 2sn site and Nushi the creator of this and the RCMS program 8)
The program above has many plugins available from a few sites. I,ll try to give a list of the more reliable sites first :)
All the plugins listed here just need to be placed into the same folder as nushichat to work.
This is a plug into increase the speed of the room listing which used to take some time. (from 2sn)
http://2sen.dip.jp/arcs/ListClient.zip
This plugin allows you to use the nushi client to do admin by making it compatible with the Rcms commands (from Vladd44)
http://www.vladd44.com/adminnushi.zip
This plugin will show the system uptime and also the local time , just type in the word "STAT" (Vladd44)
http://www.vladd44.com/TimePlugin.zip
This plugin will allows ppl in the chatroom to view your currently playing winamp selection. It will work on all winamp versions except 3.X . It is activated by typing the word "MUSIC" . (Vladd44)
http://www.vladd44.com/MusicPlugin.zip
This is a simple AI Bot that can be added (MXtools)
http://www.mxtools.net/addons/nushi/dl/AI.zip
This is a plugin to prevent Nushi spamming out of chat rooms (called originally enough "antispam"). (MXtools)
http://www.mxtools.net/addons/nushi/dl/Antispam.zip
This plugin will measure the rooms lag to see how much lag is in the room. The User types lag to view statistic type LAG (mxtools)
http://www.mxtools.net/addons/nushi/dl/LagCheck.zip
This plugin is an improvement over the standard Nushi log plugin , this one logs each room to a seperate file with an index page listing all the logs, The logs are in HTML format . If the logger appears to do nothing create a folder called "logs" in the same folder as you placed nushichat. (MXtools )
http://www.mxtools.net/addons/nushi/dl/Nushilogger.zip
I was online rather late last night and was unable to finish all the plugins so here is some more... :D
This is a plugin that beeps when a keyword is typed in to the chatroom, ( this plugin was also the base for the original mxbot 1.X. series). (mxtools)
http://www.mxtools.net/addons/nushi/dl/MXChatBeep.zip
This plugin logs the contents of the chat room to a text file. It doesn't work in rooms with symbols in the name, Very annoying. (mxtools)
http://www.mxtools.net/addons/nushi/dl/Nushilog.zip
This is a voice synthesiser which tranlates the on screen text into sounds. mxtools)
http://www.mxtools.net/addons/nushi/dl/TalkPlugin.zip
This plugin adds text before and after everything you type depending on how you set it up .(mxtools)
http://www.mxtools.net/addons/nushi/dl/FixText.zip
This plugin allows you to ignore any user you choose (/ignore (user here). (mxtools)
http://www.mxtools.net/addons/nushi/dl/IgnorePlugin.zip
This plugin is the old admin one. The enhanced one appears in the last post.(mxtools)
http://www.mxtools.net/addons/nushi/dl/KuruKuru.zip
As the Mxtools site has had a makeover Some of the above links will not perform as required ..sorry ppl
I have located another source of most of them but some may not be available.
If I have time I will compile a list of the new links for you in the meantime check here.
http://www.winmxunlimited.netfirms.com/mxtools.html
If you require a specific Item thats unavailable I have an archive of 99% of the ones featured here so just ask .
A small note here for anyone thinking of updating the connecting IP in Nushichat
When connecting Frontcode the Winmx beta (3 at the moment) is accessing 66.132.146.48 on port 5690 .
