I have successfully integrated phpbb in my website(http://forums.cricketmx.com/viewtopic.php?f=63&t=5036), and I'm wondering if there is anyway I can embed two instances of the script on the same page.
ie I want a main section that is already setup, pulling from a certain area of the forum (News), and then a second that pulls from a different part of the forums(Events) that is displayed in a small box on the side(like an event display, while the other displays current news). I thought I might be able to just run two instances of the script at the same time, but I get an error: Fatal error: Cannot redeclare create_where_clauses() (previously declared in /home/thegif15/public_html/xo/tester2.php:24) in /home/thegif15/public_html/xo/cwpull.php on line 100
the area around line 100 on both files looks like this(starting at line 94):
return $out_where;
$search_limit = 5;
$forum_id = array(3);
$topic_id = array();
$posts_ary = array(
'SELECT' => 'p.*, t.*',
'FROM' => array(
POSTS_TABLE => 'p',
'LEFT_JOIN' => array(
array(
AND t.topic_approved = 1',
);obviously trying to declare the forum array twice is screwing it up.
I understand that the fact that its telling the same page to do the same thing twice from 2 different places is causing an error, But I am not sure how to fix it. Trying to pull the second php file in via different methods still causes errors, is there some way I can fix this. I understand if you don't have any idea how to do this, neither do I!!
thx -ape
