[BETA 4] Calendar Alerts MOD v0.0.4
Hmm :?
Find
redirect(append_sid("{$phpbb_root_path}ucp.$phpEx", "i=alerts&mode=alerts"));
Replace with:
else if( !$_POST )
FIND:
confirm_box(false, 'UCP_ALERTS_DELETE');
Replace with:
Does that fix it?
pluto
Hello
This is exactly the same :cry:
When I click to delete an alert, it nothing happens.
There is no longer the expression "Are you sure you want to delete this alert ? "
Here is my file: ucp_alerts.php
Thank you again.
pluto
Hello,
Person for the solution ?
Thank you.
pluto
Hello,
For additional information, trying to undo the deletion of an alert on your forum by clicking "No", you get a blank page :!:
Thank you for your answers.
I'm sorry for the slow reply pluto I have been quite busy :cry: :cry: :cry:
Try this:
find:
			if (confirm_box(true))
				$sql = "DELETE FROM " . ALERTS_TABLE . "
						WHERE alert_id = " . request_var('delete', 0) . "
						AND user_id = " . $user->data['user_id'];
				$db->sql_query($sql);
				// Clear the cache
				$cache->destroy('sql', ALERTS_TABLE);
				trigger_error( sprintf($user->lang['UCP_ALERTS_DELETE_SUCCESS'], "<a href='" . append_sid($this->u_action) . "'>", "</a>") );
			else if( !$_POST )
Replace with:
				// Clear the cache
What happens if you do this? :)
pluto
Good evening,
No luck, now I find myself again with the line:
template->_tpl_load_file(): File ./styles/acidtech/template/.html does not exist or is empty :?
Thank you.
pluto
Hello,
A little up, thank you.
Pluto.
pluto
Hello,
No one to support ?
Thanks.
pluto, I'm looking at http://up.sur-la-toile.com/iCEe - if you replace:
		if($delete) // delete an event
				// Clear the cache
			else if( !$_POST )
With
				// Clear the cache
Is that okay?
Sorry for the delay again :oops:
pluto
Hello,
The removal works perfectly, cons, there is more demand confirmation of removal.
Thanks.
I think I have an idea to add the confirmation back :D
Try replacing
            // Clear the cache
With
      if(request_var('confirm', 0) > 0) // confirm
            // Clear the cache
      trigger_error('Please confirm that you wish to delete this event: <a href="' . append_sid($this->u_action . '&confirm=1') . '">Confirm</a>');
Let me know if that works :)
pluto
Good evening,
No, when I click, it brings me back to the panel without removing the alert :|
victory1
pluto wrote:Hello,
When I want to cancel a deletion warning, I get this error:
Général error
Thank you to you.
I migrated from another forum software on October 25th and I am slowly adding Mods to my new phpBB forum. My old forum had something similar built in so I knew what I was looking for. I found this and the Calendar 0.1.0 (alightner) which is a little to complicated for what I have in mind. I'm also getting the same error as the above poster when I cancel delete!
General Error
template->_tpl_load_file(): File ./styles/redsteel/template/.html does not exist or is empty
Also when do you plan to add the bbcode functionality? I saw it was mentioned several times in the phpBB Support forum. I would love to add an url to direct them to the forum, topic, or post that the alert is referring to.
victory1
No answers forthcoming? :?: Thanks :)
Have some suggestions for your excellent Calendar Alerts MOD, battye. ;)
1. At present, when adding a new Alert, if no year is specified when submitting, you'll be informed of this. Is is possible to change it so if no year isn't specified, it takes the Alert entry as "repeat for every year"? Would be handy for Birthday reminders, Christmas Day, Valentine Day, etc. Basically where the day/month never changes each year.
2. Suggestion: Edit mode. Saves deleting and re-creating because of mistake.
3. Limit admin global alerts to logged in members only / or set global alert visibility by usergroup.
