Hey there,
So I followed wht's on your article here: http://www.cricketmx.com/articles/read/ ... in-phpbb3/
I use frontpage to edit the my webpages and then pass it to php, and it worked fine.
But then I wanted to display the topics on a different layer, and it gives me the following error, as you can see here: http://7cr9.com/home.php
What should I do?
I hope I had made myself clear.
Thanks in advance,
Mary
phpbb Displaying topics from external pages
You are talking about these errors I take it? "phpBB Debug] PHP Notice: in file /includes/session.php on line 1007: Cannot modify header information - headers already sent by (output started a..."
This is normally quite an easy sort of thing to fix (usually just requires moving a few pieces of code around). Are you able to paste the code for that whole page here (or at least the areas related to the php)? What I think has happened is Frontpage has interfered a little bit - don't worry though, as I said it should be easy to fix.
Ok, now it doenst give me that error anymore...
I was trying to fix it by myself, so I added this code on the top of my page:
$phpbb_root_path = './forum/'; // Path to phpbb folder
// Start session management
$user->session_begin();
$auth->acl($user->data);
// Grab user preferences
$user->setup();
And this code where I want the topics to appear:
/*** phpBB3 - Last Active Topics System ***/
//Show last x topics
define('TOPICS_LIMIT',10);
// Create arrays
$topics = array();
// Get forums that current user has read rights to.
$forums = array_unique(array_keys($auth->acl_getf('f_read', true)));
// Get active topics.
$sql="SELECT *
FROM " . TOPICS_TABLE . "
WHERE topic_approved = '1' AND " . $db->sql_in_set('forum_id', $forums) . "
ORDER BY topic_last_post_time DESC";
$result = $db->sql_query_limit($sql,TOPICS_LIMIT);
while ($r = $db->sql_fetchrow($result))
$topics[] = $r;
$db->sql_freeresult($result);
<div>
foreach($topics as $t)
// Get folder img, topic status/type related information
$topic_tracking_info = get_complete_topic_tracking($t['forum_id'], $t['topic_id']);
$unread_topic = (isset($topic_tracking_info[$t['topic_id']]) && $t['topic_last_post_time'] > $topic_tracking_info[$t['topic_id']]) ? true : false;
$folder_img = $folder_alt = $topic_type = '';
topic_status($t, $t['topic_replies'], $unread_topic, $folder_img, $folder_alt, $topic_type);
// output the link
<img style="vertical-align: text-bottom" src="<?=$user->img($folder_img, $folder_alt, false, '', 'src');?>" title="<?=$user->lang[$folder_alt];?>" alt="<?=$user->lang[$folder_alt];?>" />
<a href="<?=$phpbb_root_path . 'viewtopic.php?f=' . $t['forum_id'] . '&t=' . $t['topic_id'] . '&p=' . $t['topic_last_post_id'] . '#p' . $t['topic_last_post_id'];?>"><?=html_entity_decode($t['topic_title']);?></a><br />
</div>
I use Frontpage to edit my webpages, so a created a home.php page from scratch, without nothing elese but thhis code, and it functioned perfectly, you can check it here: http://7cr9.com/home.php
But then I tries to include it on my actual Home page, but it is written in HTML, and then almost all teh stuff disappeared, but the link to the forum remains (below the chatbox) you can check it here: http://7cr9.com/exp1.php
My question is how can I integrate this code on a separate layer on frontpage without getting teh error I got here: http://7cr9.com/exp1.php ?
I read in some forum about using ssi to convert php to html or something like that...?
I'm very confused as you may have noticed, hope you have understood.
thanks for your time,
Mary
$user->setup();
// Create arrays
$topics = array();
$sql="SELECT *
$topics[] = $r;
<div>
// output the link
</div>
Mary
I actually get errors on both of those pages you linked to, so I don't think it is functioning perfectly on either?
Is this the first few lines of the file:
ie. there is absolutely nothing above that?
$phpEx = substr(strrchr(__FILE__, '.'), 1);CricketMX.com in 2022: Still the home of bat's, rat's and other farmyard animals!
Here is the full html code from home.php
and teh code for exp1.php
Is there something wrong?
Thanks ,
Mary
<html>
$user->setup();
<head>
<meta http-equiv="Content-Type" content="text/html; charset=windows-1252">
<title>Nova pagina 1</title>
</head>
<body>
<div style="position: absolute; width: 302px; height: 309px; z-index: 1; left: 536px; top: 195px" id="camada1">
// Create arrays
$topics = array();
$sql="SELECT *
$topics[] = $r;
<div>
// output the link
</div> </div>
</body>
</html>
<html xmlns:v="urn:schemas-microsoft-com:vml" xmlns:o="urn:schemas-microsoft-com:office:office" xmlns="http://www.w3.org/TR/REC-html40">
$user->setup();
<head>
<meta name="verify-v1" content="rIWTFpQLuOArySY8IOB8fkfbi9xD7kCgfKc43/tC2xE=" />
<title>7CR9, site fãs de Cristiano Ronaldo CR9 /7 (Cristiano Ronaldo fansite)</title>
<script language="JavaScript">
// --><script type="text/javascript" src="http://www.haloscan.com/load/mariamsr"> </script>
</script>
<style>
.ms-simple1-main { border-left-style: none; border-right-style: none;
border-top: 1.5pt solid green; border-bottom: 1.5pt solid green }
.ms-simple1-tl { border-left-style: none; border-right-style: none; border-top-style: none;
border-bottom: .75pt solid green }
.ms-simple1-left { border-style: none }
.ms-simple1-top { border-left-style: none; border-right-style: none; border-top-style: none;
.ms-simple1-even { border-style: none }
</style>
</head>
<meta name="verify-v1" content="eFju5IN4adFN1ySnXJW/xJuer91o13rkr2qn3VmL7wY=" />
<body>
<div style="border:3px double #000000; position: absolute; width: 943px; height: 23px; z-index: 4; left: 25px; top: 577px; visibility:visible; background-color:#000000" id="camada4">
<div style="position: absolute; width: 227px; height: 964px; z-index: 1; left: 782px; top: 94px; background-color:#FFFFFF; background-image:url('../7cr9/Coluna%20Direita.jpeg')" id="camada17">
<div style="position: absolute; width: 111px; height: 100px; z-index: 9; left: 129px; top: -72px" id="camada51">
<div style="position: absolute; width: 100px; height: 99px; z-index: 1; left: -126px; top: 1458px" id="camada52">
// Create arrays
$topics = array();
$sql="SELECT *
$topics[] = $r;
<div>
// output the link
</div></div>
<b><font color="#FF6600" face="Arial" size="2">Em reconstrução</font></b></div>
<p style="margin-top: 0; margin-bottom: 0">
</p>
</p>
</p>
<b><i>
<font face="Arial" size="2" color="#FFFFFF"> </font></i></b>
</p>
<div style="position: absolute; width: 197px; height: 259px; z-index: 1; left: 18px; top: 50px" id="camada34">
<b><span style="background-color: #000000"><i>
<font face="Arial" size="2" color="#FFFFFF">Vídeos </font></i></span>
<font face="Arial" color="#FFFFFF" size="2">
</span> </font></b></p>
<b><font face="Arial" color="#800000">- </font>
<font face="Arial" size="2">Making of anúncio BES "I Gotta Feeling" TVI</font></b></p>
<font face="Arial" size="2">Entrevista exclusiva TVI 9/4/10</font></b></p>
<font face="Arial" size="2">Novo anúncio BES 9/4/10</font></b></p>
<font face="Arial" size="2">Conf.imprensa 8/4/10</font></b></p>
<font size="2" face="Arial">Racing Santander vs CR</font></b></p>
<font face="Arial" size="2">CR vs Atlético Madrid</font></b></p>
<font face="Arial" size="2">Getafe vs CR</font></b></p>
<font face="Arial" size="2">CR vs Sporting Gijón</font></b></p>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
<p> </div>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
<div style="position: absolute; width: 199px; height: 235px; z-index: 2; left: 16px; top: 277px" id="camada35">
<span style="background-color: #000000"><b><i>
<font face="Arial" size="2" color="#FFFFFF">Galeria </font></i>
</b></span><b><span style="background-color: #000000"><i>
<font face="Arial" size="2" color="#FFFFFF"> </font></i></span><font face="Arial" color="#FFFFFF" size="2"><span style="background-color: #000000">
</span></font></b></p>
<b><font face="Arial" size="2" color="#800000"><i>- </i></font>
<font face="Arial" size="2">Real Madrid 1-0 Lyon </font></b>
<font face="Arial" size="2">(jogos Real Madrid 09/10)</font></p>
<b><i><font face="Arial" size="2" color="#800000">- </font></i>
<font face="Arial" size="2">Treino 8, 9 e 12 Março </font></b>
<font face="Arial" size="2">(treinos Real Madrid 09/10)</font></p>
<font face="Arial" size="2">Conf.imprensa 8-3-10 </font></b>
<font face="Arial" size="2">(conf.imprensa)</font></p>
<font face="Arial" size="2">Apresentação Bilhetes Final Champions League
</font></b><font face="Arial" size="2">(variados)</font></p>
<font face="Arial" size="2">Portugal 2-0 China </font></b>
<font face="Arial" size="2">(jogos Selecção Nacional Qualificação
Mundial2010)</font></p>
<font face="Arial" size="2">Treino 2 Março (</font></b><font face="Arial" size="2">treinos
Selecção Nacional qualificação Mundial2010)</font></p>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
</div>
<div style="position: absolute; width: 194px; height: 100px; z-index: 4; left: 22px; top: 548px" id="camada37">
<table border="1" width="98%" id="table3">
<tr>
<td width="65" align="center"> </td>
<td width="20" align="center"><b>
<font face="Arial" size="2">J</font></b></td>
<td width="22" align="center"><b>
<font face="Arial" size="2">G</font></b></td>
<td align="center" width="22"><b>
<font face="Arial" size="2">A</font></b></td>
<td align="center"><b><font size="2" face="Arial">Total
G</font></b></td>
</tr>
<tr>
<td width="65" align="left"><b>
<font face="Arial" size="2">La Liga</font></b></td>
<td width="20" align="center"><b><font face="Arial" size="2">21</font></b></td>
<td width="22" align="center"><b><font face="Arial" size="2">18</font></b></td>
<td align="center" width="22"><b><font face="Arial" size="2">4</font></b></td>
<td align="center"><b><font face="Arial" size="2">18</font></b></td>
</tr>
<tr>
<td width="65" align="left"><b><font face="Arial" size="2">Champions
League</font></b></td>
<td width="20" align="center"><b><font face="Arial" size="2">6</font></b></td>
<td width="22" align="center"><b><font face="Arial" size="2">7</font></b></td>
<td align="center" width="22"><font face="Arial" size="2"><b>0</b></font></td>
<td align="center"><b><font face="Arial" size="2">7</font></b></td>
</tr>
<tr>
<b><font face="Arial" size="2">Copa del Rey</font></b></td>
<td width="20" align="center"><b>´0</b></td>
<td width="22" align="center"><b>0</b></td>
<td align="center" width="22"><b>0</b></td>
<td align="center"><b>0</b></td>
</tr>
<tr>
<font face="Arial" size="2">Portugal</font></b></td>
<td width="20" align="center"><b>4</b></td>
<td align="center" width="22"><b>2</b></td>
</tr>
<tr>
<font face="Arial" size="2">Pré-época RealMadrid</font></b></td>
<td width="20" align="center"><b><font face="Arial" size="2">9</font></b></td>
<td width="22" align="center"><b><font face="Arial" size="2">3</font></b></td>
<font face="Arial" size="2">0</font></b></td>
<td align="center"><b><font face="Arial" size="2">3</font></b></td>
</tr>
</table>
<p style="margin-top: 0; margin-bottom: 0"> </p>
</div>
<p style="margin-top: 0; margin-bottom: 0"><b>
</font></b></p>
<div style="position: absolute; width: 197px; height: 100px; z-index: 3; left: 18px; top: 793px" id="camada36">
<table border="1" width="89%" id="table2">
<tr>
<td width="104" align="center"> </td>
<td width="18" align="center"><b>
<td width="27" align="center"><b>
<font face="Arial" size="2">Pts</font></b></td>
</tr>
<tr>
<td width="104" align="left"><font face="Arial" size="2"><b>1.</b></font><b><font face="Arial" size="2">REALMADRID</font></b></td>
<td width="18" align="center"><font size="2"><b>29</b></font></td>
<td width="27" align="center"><b><font face="Arial" size="2">74</font></b></td>
</tr>
<tr>
<td width="104" align="left" height="22"><b><font face="Arial" size="2">
2.BarcelonaFC</font></b></td>
<td width="18" align="center" height="22">
<td width="27" align="center" height="22">
<font size="2"><b>74</b></font></td>
</tr>
<tr>
<td width="104" align="left"><b><font face="Arial" size="2">3. Valencia
CF</font></b></td>
<td width="27" align="center"><font size="2"><b>53</b></font></td>
</tr>
<tr>
<td width="104" align="left"><b><font face="Arial" size="2">4.
RCD Mallorca</font></b></td>
<td width="18" align="center"><b><font face="Arial" size="2">29</font></b></td>
<td width="27" align="center"><b><font face="Arial" size="2">47</font></b></td>
</tr>
</table>
</div>
</div>
<marquee bgcolor="#FFFFFF" style="font-family: Arial">Prox Jogo: 10 Abril Real Madrid vs Barcelona FC (21:00 hora Portugal) -- Racing Santander 0-2 Real Madrid (1 golo de Ronaldo!) ---Videos para download: Making of anúncio BES "I Gotta Feeling" TVI; Entrevista exclusiva TVI 9/4/10; Novo anúncio BES 9/4/10; Conf.imprensa 8/4/10; Racing Santander vs CR: Getafe vs CR</marquee></div>
<div style="border-style:outset; border-color:#C0C0C0; position: absolute; width: 230px; height: 408px; z-index: 9; left: 811px; top: 1641px" id="camada19">
<!-- BEGIN CBOX - http://www.cbox.ws - v001 -->
<div id="cboxdiv" style="text-align: center; line-height: 0">
<div><iframe frameborder="0" width="200" height="305" src="http://www6.cbox.ws/box/?boxid=403066&boxtag=ylw2vt&sec=main" marginheight="2" marginwidth="2" scrolling="auto" allowtransparency="yes" name="cboxmain" style="border:#DBE2ED 1px solid;" id="cboxmain"></iframe></div>
<div><iframe frameborder="0" width="200" height="75" src="http://www6.cbox.ws/box/?boxid=403066&boxtag=ylw2vt&sec=form" marginheight="2" marginwidth="2" scrolling="no" allowtransparency="yes" name="cboxform" style="border:#DBE2ED 1px solid;border-top:0px" id="cboxform"></iframe></div>
</div>
<!-- END CBOX --></div></div>
<p align="center">
</p>
<div style="position: absolute; width: 845px; height: 100px; z-index: 11; left: 95px; top: 18px" id="camada23">
<img border="0" src="../7cr9/Principal.jpeg" width="851" height="546"></div>
<div style="position: absolute; width: 203px; height: 1416px; z-index: 2; left: 2px; top: 674px; padding-left: 4px; padding-right: 4px; padding-top: 1px; padding-bottom: 1px; background-color: #FFFFFF; visibility:visible; background-image:url('../7cr9/Barra%20Esquerda.jpeg')" id="camada2">
<p style="margin-top: 0; margin-bottom: 0" align="center">
<i><u>
<font face="Arial"> </font></u></i></p>
<div style="position: absolute; width: 608px; height: 12715px; z-index: 3; left: 191px; top: 1417px; border-left-style: solid; border-left-width: 1px; border-right-style: outset; border-right-width: 1px; border-bottom-style: outset; border-bottom-width: 1px; padding-left: 4px; padding-right: 4px; padding-top: 1px; padding-bottom: 1px" id="camada50">
</div>
<div style="position: absolute; width: 601px; height: 14129px; z-index: 4; left: 197px; top: -1px; visibility:visible" id="camada26">
<div style="position: absolute; width: 1085px; height: 58px; z-index: 2; left: -191px; top: -72px" id="camada27">
<a href="http://7cr9.com/Home.php">
<img border="0" src="../7cr9/Home%20menu.jpeg" width="128" height="66"></a><a href="Sobre%20ele.htm"><img border="0" src="../7cr9/Sobre%20Ele%20menu.jpeg" width="125" height="64"></a><a href="Noticias.htm"><img border="0" src="../7cr9/Noticias%20menu.jpeg" width="128" height="67"></a><a href="Videos.htm"><img border="0" src="../7cr9/Videos%20menu.jpeg" width="134" height="69"></a><a href="http://7cr9gallery.co.cc/Gallery/index.php"><img border="0" src="../7cr9/Galeria%20menu.jpeg" width="139" height="72"></a><a href="Chat.htm"><img border="0" src="../7cr9/Chat%20menu.jpeg" width="137" height="73"></a><a href="Sobreosite.htm"><img border="0" src="../7cr9/Sobre%20o%20site.jpeg" width="128" height="71"></a><a href="http://7cr9.com/forum/"><img border="0" src="../7cr9/Forum.menu.jpeg" width="123" height="69"></a></div>
<p align="center">
<img border="0" src="../7cr9/Ultimas%20Noticias.JPG" width="328" height="68"><p align="center">
<font face="Arial"> <?PHP
$number=12;
$only_active=TRUE;
include("/home/crcom/public_html/cutenews/show_news.php");
?></font><div style="position: absolute; width: 522px; height: 100px; z-index: 3; left: 43px; top: 14163px" id="camada32" align="center">
<font face="Arial" size="2"><font color="#666666"><u>7</u></font><a href="http://www.7cr9.com"><font color="#666666">CristianoRonaldo9
- 7cr9.com</font></a><font color="#666666"> © 2009 - Webhost:
- </font><a href="mailto:mary17.7cr9@gmail.com"><font color="#666666">
Contactar 7CR9</font></a></font><div style="position: absolute; width: 91px; height: 47px; z-index: 1; left: 310px; top: -15px" id="camada33">
</div>
<p align="center"><font face="Arial" size="2" color="#666666">7CR9 não é
o site oficial do Cristiano Ronaldo, e não tenho qualquer contacto com o
jogador, familiares ou amigos. </font> </div>
</div>
<font size="5" face="Pristina">
</font>
</p>
</p>
</p>
</p>
</p>
</p>
<font face="Pristina" size="2"> </font></p>
<b>
<i><u>
<font face="Arial">XMaryX17X </font></u></i></b></p>
______________________</p>
<font face="Arial" size="2"><b> </b> </font></p>
<div style="position: absolute; width: 101px; height: 23px; z-index: 12; left: 13px; top: 207px" id="camada49">
<b><font face="Arial" size="2">7CR9 promo!</font></b></div>
<div style="position: absolute; width: 100px; height: 100px; z-index: 5; left: 28px; top: 383px" id="camada38">
<object width="155" height="125"><param name="movie" value="http://www.youtube.com/v/v7hS3ryG4ak&hl=pt-br&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/v7hS3ryG4ak&hl=pt-br&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="155" height="125"></embed></object>
</div>
</p>
</p>
</p>
</p>
<font face="Arial" size="2"> </font></p>
</p>
<div style="position: absolute; width: 101px; height: 23px; z-index: 12; left: 31px; top: 369px" id="camada47">
<b><font face="Arial" size="2">Everything</font></b></div>
<div style="position: absolute; width: 180px; height: 141px; z-index: 13; left: 5px; top: 223px" id="camada48">
<object width="183" height="145"><param name="movie" value="http://www.youtube.com/v/5-TjVYXfiRI&hl=pt-br&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/5-TjVYXfiRI&hl=pt-br&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="183" height="145"></embed></object></div>
</p>
</p>
</p>
<font face="Arial" size="2"><b> </b></font></p>
<div style="position: absolute; width: 140px; height: 113px; z-index: 5; left: 28px; top: 522px" id="camada39">
<object width="155" height="125"><param name="movie" value="http://www.youtube.com/v/9dbWcSxIPxA&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/9dbWcSxIPxA&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="155" height="125"></embed></object>
</div>
<div style="position: absolute; width: 100px; height: 19px; z-index: 11; left: 30px; top: 508px" id="camada46">
<b><font face="Arial" size="2">Best of 2008</font></b></div>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
</p>
<p class="MsoNormal" style="margin-top: 3px; margin-bottom: 3px">
</p>
</p>
<p style="margin-top: 0; margin-bottom: 0" align="justify">
</p>
<span style="font-weight: 700" lang="en-gb">
</span></p>
<font face="Arial" color="#800000"> </font></span></p>
<div style="position: absolute; width: 181px; height: 100px; z-index: 10; left: 14px; top: 676px" id="camada45">
<font face="Arial" color="#800000">-</font><font face="Arial" size="2"> </font>
<a href="mailto:mary17.7cristianoronaldo7@gmail.com">
<font face="Arial" size="2" color="#000000">mary17.7cr9@gmail.com</font></a></span></div>
</p>
</p>
</p>
<b><font face="Arial"> </font></b></p>
<div style="position: absolute; width: 152px; height: 100px; z-index: 9; left: 16px; top: 765px" id="camada44">
<b><font face="Arial"> </font></b><span style="font-weight: 700" lang="en-gb"><font face="Arial" color="#800000">- </font>
</span><b><font size="2" face="Arial">
<a href="http://7cristianoronaldo9.hi5.com"><font color="#000000">Hi5 </font></a></font></b><font size="2">
</font></p>
<font size="2"> </font><span style="font-weight: 700" lang="en-gb"><font face="Arial" color="#800000">- </font>
</span><b>
<a href="http://www.facebook.com/home.php#/profile.php?id=100000146352936&ref=profile">
<font size="2" color="#000000" face="Arial">Facebook</font></a></b></p>
<span style="font-weight: 700">
<font size="2" face="Arial"> </font></span><span style="font-weight: 700" lang="en-gb"><font face="Arial" color="#800000">- </font>
</span><b><a href="http://twitter.com/7cronaldo9">
<font size="2" color="#000000" face="Arial">Twitter</font></a></b></p>
<p style="margin-top: 0; margin-bottom: 0" align="left">
</span><b>
<a href="http://www.orkut.com/Main#Profile.aspx?uid=7975519524822680467">
<font size="2" color="#000000" face="Arial">Orkut</font></a></b></p>
</span><b><a href="http://www.myspace.com/492095675">
<font size="2" color="#000000" face="Arial">Myspace</font></a></b></p>
</span><b><a href="http://www.tagged.com/7cristianoronaldo9">
<font size="2" color="#000000" face="Arial">Tagged</font></a></b></p>
<p> </div>
</p>
</p>
<p style="margin-top: 0; margin-bottom: 0" align="justify"> </p>
</p>
<div style="position: absolute; width: 176px; height: 100px; z-index: 8; left: 16px; top: 938px" id="camada43">
<p align="left" style="margin-top: 0px; margin-bottom: 0px">
</span><b><font face="Arial" size="2" color="#FFFFFF">
<a href="http://cristianoronaldo7-17.blogspot.com/"><font color="#000000">
Cristiano Ronaldo7-17 Blog</font></a></font></b></p>
<a href="http://www.xmaryx17cristianoronaldovideos.blogspot.com/">
<font color="#000000">XMaryX17 Vídeos</font></a></font></b></p>
</span><b><font color="#FFFFFF" size="2" face="Arial">
<a href="http://br.youtube.com/profile?user=XxXMaryX17XxX">
<font color="#000000">My channel on Youtube</font></a></font></b></p>
<b><font face="Arial" size="2">-
<a href="http://www.facebook.com/Cristiano?v=wall"><font color="#000000">
Facebook C.Ronaldo</font></a></font></b></p>
-</span></font><span lang="en-gb"> </span><b>
<a href="http://www.gestifute.com/gestifute/index_mundial.html">
<font color="#000000">Gestifute</font></a></font></b></p>
<a href="http://www.fpf.pt/portal/page/portal/PORTAL_FUTEBOL">
<font color="#000000">FPF</font></a></font></b></p>
</span><b><u>
<a href="http://www.realmadrid.com/cs/Satellite/es/Home.htm">
<font color="#000000">Real MadridFC Official Site</font></a></font></u></b></p>
<p> </div>
</p>
</p>
<p align="left" style="margin-top: 0; margin-bottom: 0">
<font color="#000000" face="Arial" size="2"> </font></p>
<div style="position: absolute; width: 176px; height: 100px; z-index: 7; left: 13px; top: 1121px" id="camada42">
<font face="Arial" color="#800000"> - </font>
</span><font face="Arial" size="2" color="#FFFFFF">
<b><a href="http://www.ronaldofan.com/"><font color="#000000">Ronaldo Você É Bonito</font></a></b></font></p>
<b>
<font color="#000000" size="2" face="Arial"> </font><font color="#800000" face="Arial">- </font>
<a href="http://cristiano-ronaldo.us/"><font color="#000000">CristianoRonaldo.us</font></a></font></b></p>
<a href="http://www.cr9brasil.blogspot.com/">
<font color="#000000" size="2" face="Arial">CR9 Brasil</font><font color="#000000" face="Arial"> </font></a></span></p>
<span style="font-weight: 700" lang="en-gb"><font face="Arial">
<font color="#800000"> -</font> <font size="2">
<a href="http://everythingcr7.netne.net/"><font color="#000000">EverythingCR7</font></a></font></font></span></p>
</span><b><font face="Arial" color="#FFFFFF">
<u>
<a href="http://davidluiz-23.blogspot.com/"><font color="#000000" size="2">David
Luiz 23*</font></a></u></font></b></p>
<b>
<font color="#000000" size="2" face="Arial"> </font></b><span style="font-weight: 700" lang="en-gb"><font face="Arial" color="#800000">- </font>
</span><b><font color="#FFFFFF" face="Arial">
<a href="http://lucascr7futebolmundial.blogspot.com/">
<font color="#000000" size="2">Futebol Mundial</font></a></font></b></p>
<p> </div>
</p>
<font color="#FFFFFF"><p align="left" style="margin-top: 0; margin-bottom: 0">
<!-- INICIO DO CODIGO DO CONTADOR DE VISITAS 2W.COM.BR -->
<div style="position: absolute; width: 176px; height: 100px; z-index: 6; left: 9px; top: 1279px" id="camada41">
<div align=center>
<p style="margin-top: -4px; margin-bottom: -4px">
<a href="http://www.2w.com.br/contador-de-visitas-acessos-gratis.html">
<font color="#000000"><img src="http://contador.2w.com.br/imgcontador.php?p=ec637389" alt="" border=0></font></a></div>
<div align=center>
Obrigada pela visita!</font></div>
<p align="center" style="margin-top: -4px; margin-bottom: -4px"><!-- INICIO CONTADOR -->
<a href='http://cifradasweb.net/' id='lnolt_' target='_blank' style='font-family:Arial;font-size:11px;font-weight:bold;text-decoration:none;'>
<script language='JavaScript' src='http://blogutils.net/olct/online.php?site=www.7cristiano-ronaldo7.co.cc&interval=600'></script>
</font></a>
<a href='http://www.blogutils.net/' target='_blank' style='font-family:Arial;font-size:11px;font-weight:bold;text-decoration:none;'>
<font color="#000000">online</font></a>
<!-- FIM CONTADOR -->
<p> </div>
<p align="left" style="margin-top: -3px; margin-bottom: -3px"> <div align=center>
</div>
<p align="left"> </div>
var gaJsHost = (("https:" == document.location.protocol) ? "https://ssl." : "http://www.");
document.write(unescape("%3Cscript src='" + gaJsHost + "google-analytics.com/ga.js' type='text/javascript'%3E%3C/script%3E"));
</script>
var pageTracker = _gat._getTracker("UA-5774876-1");
pageTracker._trackPageview();
</script>
</font>
</body>
</html>
Thanks ,
Mary
I looked at your site again and the errors are not there any more. Did you fix it?
No, I didn't do anything... But do you know hoe to integrate this code into frontpage?
Because I get error, like it is seen on www.7cr9.com/exp1.php
Thanks,
mary
Thanks,
mary
I still can't see any errors on http://www.7cr9.com/exp1.php. Can you tell me what the error is that you see on http://www.7cr9.com/exp1.php
sorry to hijack this topic, but I have a similar problem and didn't want to create an unnecessary topic.
I managed to follow your installation without error, but when it came to modifying the page I kept getting the error :
The line 7 of newsfeed.php is
And the lines 4284-4287 are
And Here's the page I've been trying to create
Any help would be greatly appreciated
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 4284: Cannot modify header information - headers already sent by (output started at /home/content/c/h/u/churchofmud/html/newsfeed.php:7)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 4285: Cannot modify header information - headers already sent by (output started at /home/content/c/h/u/churchofmud/html/newsfeed.php:7)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 4286: Cannot modify header information - headers already sent by (output started at /home/content/c/h/u/churchofmud/html/newsfeed.php:7)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 4287: Cannot modify header information - headers already sent by (output started at /home/content/c/h/u/churchofmud/html/newsfeed.php:7)Code: Select all
<style type="text/css">Code: Select all
header('Content-type: text/html; charset=UTF-8');
header('Cache-Control: private, no-cache="set-cookie"');
header('Expires: 0');
header('Pragma: no-cache');Code: Select all
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="content-style-type" content="text/css" />
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<title>First Church - News</title>
div.dwheader{
width: 907px;
height: 726px;
position: absolute;
margin-left: -456px;
left: 50%;
top: 0px
!important;
top:150px;
body table {margin-top:735px;}
body td table,
body div table {margin-top:0;}
A IMG{
border-style:none;
body {
background-image: url(http://img383.imageshack.us/img383/2919/firstchurchofmudlayoutblj2.gif);
background-position: center center;
background-attachment: fixed;
background-color:#000000;
text-align: center;
#logo {
background-image: url(/Pictures/Logo.jpg);
width: auto;
height: 534px;
background-repeat: no-repeat;
background-position: center top;
background-attachment: scroll;
overflow: auto;
body {
margin: 0px;
padding: 0px;
text-align: center;
border-top-width: 0px;
border-right-width: 0px;
border-bottom-width: 0px;
border-left-width: 0px;
border-bottom-style: none;
top: 0px;
font-size: large;
color: #F00;
.nav {
font-size: small;
color: #003;
</style></head>
<body>
<div id="logo">
</div>
$phpbb_root_path = './Forum/'; // path to phpbbfolder
$user->setup('viewforum');
$search_limit = 5;
$posts_ary = array(
'SELECT' => 'p.*, t.*, u.username, u.user_colour',
'FROM' => array(
POSTS_TABLE => 'p',
'LEFT_JOIN' => array(
array(
'FROM' => array(USERS_TABLE => 'u'),
'ON' => 'u.user_id = p.poster_id'
array(
'ON' => 'p.topic_id = t.topic_id'
'WHERE' => $db->sql_in_set('t.forum_id', array_keys($auth->acl_getf('f_read', true))) . '
AND t.topic_approved = 1',
$post_author = get_username_string('full', $posts_row['poster_id'], $posts_row['username'], $posts_row['user_colour']);
$post_date = $user->format_date($posts_row['post_time']);
$post_link = append_sid("{$phpbb_root_path}viewtopic.$phpEx", "p=" . $posts_row['post_id'] . "#p" . $posts_row['post_id']);
'POST_AUTHOR' => $post_author,
'POST_DATE' => $post_date,
'POST_LINK' => $post_link,
page_header('../newsfeed.html');
'body' => 'Newspage.html'
page_footer();
?>Try removing "page_header('../newsfeed.html');" and also page_footer(); - at the moment you are trying to include both your own HTML as well as the phpBB header
thank you very much. that ended that code error, but another popped up. apparently sessions.php has this code in it that's also ***** with the header.
what should I do about that?
header('Set-Cookie: ' . $name_data . (($cookietime) ? '; expires=' . $expire : '') . '; path=' . $config['cookie_path'] . $domain . ((!$config['cookie_secure']) ? '' : '; secure') . '; HttpOnly', false);Can you copy and paste the error message here?
[phpBB Debug] PHP Notice: in file /includes/session.php on line 1007: Cannot modify header information - headers already sent by (output started at /home/content/c/h/u/churchofmud/html/newsfeed.php:7)
