Viewing Attachments on External Page
Posted: Sun Feb 19, 2012 6:31 pm
Thanks to TheGiftedApe's page and to battye for getting my external page going without them knowing
I have another question that I figured I'd start up a new thread on...
I am unable to view the attachments that are on the "original posts" that the new page pulls from.
I'm sure it's just a matter of plugging functions in the code to the News.php page, but I've tried doing this by copying the viewtopic.php into News.php and either it errors with sql or just simply doesn't show. You can see the image listed on this page, " dead.png " and to view the actual topic within the forum not on the external page, just click on the title.
http://www.dotrf.net will forward you automatically to the News.php page in question.
And here's the code for the News.php page:
* News.php
* Description: News File for displaying News topics for guild.
* Created on: February 17, 2012
* @package phpBB3
* @version $Id$
* @copyright (c) 2005 phpBB Group
* @license http://opensource.org/licenses/gpl-license.php GNU Public License
$phpbb_root_path = (defined('PHPBB_ROOT_PATH')) ? PHPBB_ROOT_PATH : './';
// Start session management
$user->session_begin();
$auth->acl($user->data);
$user->setup('viewforum');
* posts and topics */
global $db, $auth;
switch($type)
case 'forum':
$type = 'forum_id';
break;
case 'topic':
$type = 'topic_id';
break;
default:
// no restrictions
$out_where = '';
if( $size_gen_id > 0 )
if( $type == 'topic_id' )
unset($gen_id);
$gen_id = $topic_id_list;
$j = 0;
$j++;
return $out_where;
$search_limit = 5;
$forum_id = array(37);
$topic_id = array(619);
// Example 3: Display posts from specified topics
$posts_ary = array(
'SELECT' => 'p.*, t.*, u.username, u.user_colour',
'FROM' => array(
POSTS_TABLE => 'p',
'LEFT_JOIN' => array(
array(
'FROM' => array(USERS_TABLE => 'u'),
'ON' => 'u.user_id = p.poster_id'
array(
'ON' => 'p.topic_id = t.topic_id'
'WHERE' => str_replace( array('WHERE ', 'topic_id'), array('', 't.topic_id'), $topic_id_where) . '
AND t.topic_approved = 1',
$post_author = get_username_string('full', $posts_row['poster_id'], $posts_row['username'], $posts_row['user_colour']);
$post_date = $user->format_date($posts_row['post_time']);
$post_link = append_sid("{$phpbb_root_path}viewtopic.$phpEx", 'f=' . $posts_row['forum_id'] . '&t=' . $posts_row['topic_id'] . '&p=' . $posts_row['post_id']) . '#p' . $posts_row['post_id'];
'POST_AUTHOR' => $post_author,
'POST_DATE' => $post_date,
'POST_LINK' => $post_link,
// Output the page - Footer and Conclusion
page_header($user->lang['TITLE_NEWS']);
'body' => 'news_body.html'
page_footer();
