* quiz.php
* begin : Sat, May 21, 2005
* copyright : (C) 2005 Battye @ CricketMX.com
* email : cricketmx@hotmail.com
* $Id: quiz.php, v2 (May 2005) battye Exp $
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 2 of the License, or
* (at your option) any later version.
$phpbb_root_path = './';
include($phpbb_root_path . 'includes/bbcode.'.$phpEx);
include($phpbb_root_path . 'includes/functions_quiz.'.$phpEx);
$language = $board_config['default_lang'];
if (!file_exists($phpbb_root_path . 'language/lang_' . $language . '/lang_quiz.' . $phpEx))
$language = 'english';
include($phpbb_root_path . 'language/lang_' . $language . '/lang_quiz.' . $phpEx);
$userdata = session_pagestart($user_ip, PAGE_QUIZ);
init_userprefs($userdata);
// Just to help users know what version of UQM they are using, I will add it here, it will be changed in every version mind you (it is commented out purposely)
// $quiz_version = '1.2.0';
// Define mode and type
$mode = htmlspecialchars($HTTP_GET_VARS['mode']);
$type = htmlspecialchars($HTTP_POST_VARS['type']);
if($type == "multiple_choice")
$quiz_type = "multiple_choice"; // Default for 1.0.x
if($type == "true_false")
$quiz_type = "true_false"; // New in 1.1.x
if($type == "input_answer")
$quiz_type = "input_answer"; // Default for Pre 0.0.x, reapplied in 1.1.x
if( isset($HTTP_GET_VARS[POST_CAT_URL]) ) // Let's list the quizzes in a certain category, and all that jazz
$category_id = intval($HTTP_GET_VARS[POST_CAT_URL]);
$password_sql = "SELECT * FROM " . QUIZ_CATEGORY_TABLE . " WHERE category_id = $category_id";
if(!$password_result = $db->sql_query($password_sql))
message_die(GENERAL_ERROR, 'Could not obtain category password', '', __LINE__, __FILE__, $password_sql);
$password_row = $db->sql_fetchrow($password_result);
if( !$userdata['session_logged_in'] )
if( $password_row['category_permissions'] == ON || $password_row['category_permissions'] == OFF )
message_die(GENERAL_ERROR, $lang['Quiz_registered_category_permissions_no_access']);
if($password_row['category_password'] !== 'd41d8cd98f00b204e9800998ecf8427e' && quiz_check_category_password($category_id) != ON)
if( isset($HTTP_POST_VARS['password']) )
if( md5($HTTP_POST_VARS['password']) != quiz_category_password($category_id) )
message_die(GENERAL_ERROR, $lang['Quiz_category_password_wrong']);
else
$password_data = $userdata['session_quiz_categories'] . $category_id . ',';
$update_pw_data = "UPDATE " . SESSIONS_TABLE . " SET session_quiz_categories = '" . $password_data . "' WHERE session_id = '" . $userdata['session_id'] . "'";
if(!$db->sql_query($update_pw_data))
message_die(GENERAL_ERROR, '', 'Could not update password list', __LINE__, __FILE__, $update_pw_data);
redirect( append_sid("quiz.$phpEx?" . POST_CAT_URL . "=$category_id", true) );
include($phpbb_root_path . "includes/page_header.$phpEx");
$template->set_filenames(array("quiz_pw" => 'quiz_category_password_body.tpl'));
"F_FORM" => append_sid("quiz.$phpEx?" . POST_CAT_URL . "=$category_id"),
"L_SUBMIT" => $lang['Submit'],
"L_ENTER_PASSWORD" => $lang['Quiz_password_protect_information'],
"L_PASSWORD" => $lang['Quiz_password_protect']));
$template->pparse("quiz_pw");
include($phpbb_root_path . "includes/page_tail.$phpEx");
$page_title = $lang['Quiz_quizzes'] . ' :: ' . switch_to_category_name($category_id);
$template->set_filenames(array("quiz_cat" => 'quiz_category_body.tpl'));
if( isset($HTTP_POST_VARS['view_method']) )
$method = intval($HTTP_POST_VARS['view_method']);
if($method == 1)
$sql_addon = "ORDER BY quiz_name ASC";
if($method == 2)
$sql_addon = "ORDER BY quiz_id ASC";
if($method == 3)
$sql_addon = "ORDER BY quiz_type ASC";
if($method == 4)
$sql_addon = "ORDER BY quiz_author ASC";
else
$sql_addon = 'ORDER BY quiz_name ASC';
$sql = "SELECT * FROM " . QUIZ_GENERAL_TABLE . " WHERE quiz_category = '" . $category_id . "' " . $sql_addon;
message_die(GENERAL_ERROR, '', 'Could not obtain quiz name data', __LINE__, __FILE__);
if( $db->sql_numrows($result) == 0)
$template->assign_block_vars("nothing_row", array(
"L_NO_RESULTS" => sprintf($lang['Quiz_no_quizzes'], append_sid("quiz.$phpEx?mode=add"))
while($row = $db->sql_fetchrow($result))
$quiz_name = str_replace("\'", "''", $row['quiz_name']);
$quiz_id = intval($row['quiz_id']);
if( $row['quiz_author'] != -21000 )
$quiz_author = ( $row['quiz_author'] == ANONYMOUS ) ? $lang['Guest'] : "<a href=" . append_sid("profile.$phpEx?mode=viewprofile&" . POST_USERS_URL . "=" . intval($row['quiz_author']) . "") . ">" . convert_id($row['quiz_author']) . "</a>";
else
$quiz_author = $board_config['Quiz_packs_bot'];
$quiz_type = str_replace("\'", "''", $row['quiz_type']);
if( intval($row['quiz_plays']) != 1 )
$quiz_plays = sprintf($lang['Quiz_number_of_plays'], $row['quiz_plays']);
else if( intval($row['quiz_plays']) == 1 )
$quiz_plays = $lang['Quiz_number_of_play'];
// We need to let the users know which type of quiz it is surely.
if($quiz_type == MULTIPLE_CHOICE)
$ultimate_quiz_type = $lang['Quiz_type_multiple_choice'];
if($quiz_type == TRUE_FALSE)
$ultimate_quiz_type = $lang['Quiz_type_true_false'];
if($quiz_type == INPUT_ANSWER)
$ultimate_quiz_type = $lang['Quiz_type_input_answer'];
$template->assign_block_vars("play_row", array(
"U_QUIZ_LINK" => "<a href='" . append_sid("quiz.$phpEx?mode=play&" . POST_QUIZ_URL . "=" . $quiz_id . "") . "'>$quiz_name</a>",
"U_AUTHOR" => $quiz_author,
"U_TYPE" => $ultimate_quiz_type,
"U_PLAYS" => $quiz_plays));
"U_QUIZZES" => switch_to_category_name($category_id),
"U_SUBMIT_QUIZ" => "<a href='" . append_sid("quiz.$phpEx?mode=add") . "'>" . $lang['Submit_quiz'] . "</a>",
"U_STATISTICS_LINK" => "<a href='" . append_sid("quiz_stats.$phpEx") . "'>" . $lang['Quiz_stats'] . "</a>",
"L_VIEW_ALPHABETICAL" => $lang['Quiz_view_alphabetical'],
"L_VIEW_TYPE" => $lang['Quiz_view_type'],
"L_VIEW_AUTHOR" => $lang['Quiz_view_author'],
"L_VIEW_CHRONILOGICAL" => $lang['Quiz_view_chronilogical']));
$template->pparse("quiz_cat");
if( $mode == 'play' || isset($HTTP_GET_VARS[POST_QUIZ_URL]) )
quiz_permissions();
// September 10, 2005. Newest addition. In all probability not much will be done on this tonight. I made a function though :)
// Actually, I might CVS it.
$quiz_id = intval($HTTP_GET_VARS[POST_QUIZ_URL]); // Intval it now. Saves doing it every time it is called up for selection (cricket-ism).
$quiz_type = quiz_type($quiz_id);
// Let's check the stats, if the admin wants users to be able to play each quiz, once only.
if( quiz_check_moderative_status($userdata['user_id'], $quiz_id) != ON && $userdata['user_level'] != ADMIN )
if( $board_config['Quiz_Play_Once'] == ON )
$statistics_check = "SELECT * FROM " . QUIZ_STATISTICS_TABLE . " WHERE quiz_id = $quiz_id AND user_id = " . $userdata['user_id'];
if( !$statistics_check_result = $db->sql_query($statistics_check) )
message_die(GENERAL_ERROR, 'Could not get statistics data to check Quiz_Play_Once setting', '', __LINE__, __FILE__, $statistics_check);
if( $db->sql_numrows($statistics_check_result) == 1 || $db->sql_numrows($statistics_check_result) > 1 )
message_die(GENERAL_MESSAGE, $lang['Quiz_only_play_it_once']);
// Basically, there will be three sections (no prizes for guessing). This is the first. Hopefully they are not too large.
$sql = "SELECT * FROM " . QUIZ_GENERAL_TABLE . " WHERE quiz_id = " . $quiz_id;
message_die(GENERAL_ERROR, '', 'Could not obtain basic quiz data', __LINE__, __FILE__);
$general_quiz_data = $db->sql_fetchrow($result);
// Author information
$quiz_author_id = $general_quiz_data['quiz_author'];
$quiz_author_name = convert_id($general_quiz_data['quiz_author']);
$quiz_author_link = "<a href='" . append_sid("profile.$phpEx?mode=viewprofile&" . POST_USERS_URL . "=$quiz_author_id") . "'>$quiz_author_name</a>";
// Miscellaneous
$quiz_name = str_replace("\'", "''", $general_quiz_data['quiz_name']);
$quiz_category = intval($general_quiz_data['quiz_category']);
$quiz_enabled = $general_quiz_data['quiz_enabled'];
$password_sql = "SELECT * FROM " . QUIZ_CATEGORY_TABLE . " WHERE category_id = $quiz_category";
message_die(GENERAL_ERROR, '', 'Could not obtain category password', __LINE__, __FILE__, $password_sql);
if( quiz_check_category_password($quiz_category) != 1 && $password_row['category_password'] !== 'd41d8cd98f00b204e9800998ecf8427e' )
"F_FORM" => append_sid("quiz.$phpEx?mode=play&" . POST_QUIZ_URL . "=$quiz_id"),
if($board_config['Quiz_Author_Play'] == OFF && $quiz_author_id == $userdata['user_id'])
if( quiz_check_moderative_status($userdata['user_id'], $quiz_id) == ON )
message_die(GENERAL_MESSAGE, $lang['Quiz_author_cannot_play'] . '<br />' . sprintf($lang['Quiz_author_cannot_play_give_edit_options'], '<a href="' . append_sid("quiz_cp.$phpEx?mode=edit&q=$quiz_id") . '">', '</a>', '<a href="' . append_sid("quiz_cp.$phpEx?mode=delete&q=$quiz_id") . '">', '</a>', '<a href="' . append_sid("quiz_cp.$phpEx?mode=move&q=$quiz_id") . '">', '</a>'));
else
message_die(GENERAL_MESSAGE, $lang['Quiz_author_cannot_play']);
$page_title = $quiz_name;
$template->set_filenames(array("play_multiple_choice" => 'quiz_play_multiple_choice_body.tpl'));
$mod_langs = '<br />' . $lang['Quiz_cp_play_quiz_mod'] . '<br />' . sprintf( $lang['Quiz_cp_play_quiz_mod_do'], '<a href="' . append_sid("quiz_cp.$phpEx?mode=edit&" . POST_QUIZ_URL . "=$quiz_id") . '">', '</a>', '<a href="' . append_sid("quiz_cp.$phpEx?mode=delete&" . POST_QUIZ_URL . "=$quiz_id") . '">', '</a>', '<a href="' . append_sid("quiz_cp.$phpEx?mode=move&" . POST_QUIZ_URL . "=$quiz_id") . '">', '</a>');
else
$mod_langs = '';
$select_quiz_data = "SELECT * FROM " . QUIZ_MULTIPLE_CHOICE_TABLE . " WHERE quiz_id = $quiz_id";
if(!$result_quiz_data = $db->sql_query($select_quiz_data))
message_die(GENERAL_ERROR, '', 'Could not obtain advanced quiz data', __LINE__, __FILE__);
while($quiz_data = $db->sql_fetchrow($result_quiz_data))
$quiz_question = smilies_pass(bbencode_second_pass($quiz_data['quiz_question'], ''));
$quiz_question_id = $quiz_data['question_id'];
$quiz_multiple_choice = array();
$quiz_multiple_choice = explode("!*-.@.-*!", $quiz_data['quiz_alternates']);
"U_QUIZ_NAME" => $quiz_name,
"U_STATISTICS" => "<a href='" . append_sid("quiz_stats.$phpEx?" . POST_QUIZ_URL . "=$quiz_id") . "'>" . $lang['Quiz_stats'] . "</a>",
"F_FORM" => append_sid("quiz.$phpEx?mode=results"),
"F_ID" => $quiz_id,
"F_TYPE" => $quiz_type,
"F_TIME" => time(),
"L_MOD_LANGS" => $mod_langs,
"L_MULTIPLE_INFORMATION" => $lang['Quiz_multiple_information'],
"L_SUBMIT" => $lang['Submit_quiz']));
$template->assign_block_vars("quiz_row", array(
"U_QUESTION_ID" => $quiz_question_id,
"U_QUESTION" => $quiz_question,
"Q_ALTERNATE_ONE" => $quiz_multiple_choice[0],
"Q_ALTERNATE_TWO" => $quiz_multiple_choice[1],
"Q_ALTERNATE_THREE" => $quiz_multiple_choice[2],
"Q_ALTERNATE_FOUR" => $quiz_multiple_choice[3]));
$template->pparse("play_multiple_choice");
$template->set_filenames(array("play_input_answer" => 'quiz_play_input_answer_body.tpl'));
else
$mod_langs = '';
$select_quiz_data = "SELECT * FROM " . QUIZ_INPUT_TABLE . " WHERE quiz_id = $quiz_id";
// I've decided not to encode the answer, it is easier to compare it to an id, such as the game_id / quiz_id partnership in 1.0.6
"F_ID" => $quiz_id,
"F_TIME" => time(),
"L_INPUT_INFORMATION" => $lang['Quiz_input_information'],
"U_QUESTION" => $quiz_question));
$template->pparse("play_input_answer");
$template->set_filenames(array("play_true_false" => 'quiz_play_true_false_body.tpl'));
else
$mod_langs = '';
$select_quiz_data = "SELECT * FROM " . QUIZ_TRUE_FALSE_TABLE . " WHERE quiz_id = $quiz_id";
$quiz_answer = $quiz_data['quiz_answer'];
"F_ID" => $quiz_id,
"F_TIME" => time(),
"L_TRUE_FALSE_INFORMATION" => $lang['Quiz_true_false_information'],
"L_TRUE" => $lang['Quiz_answer_true'],
"L_FALSE" => $lang['Quiz_answer_false'],
"U_ANSWER" => md5($quiz_answer)));
$template->pparse("play_true_false");
if($mode == 'add')
quiz_permissions();
$quiz_questions_explode = explode(',', $board_config['Quiz_Min_Max_Questions']);
if( $board_config['Quiz_Mod_Submit'] == ON && quiz_check_moderative_status($userdata['user_id'], '') != ON )
message_die(GENERAL_MESSAGE, $lang['Quiz_only_mod_can_submit']);
if(!$HTTP_POST_VARS['Questions_number'] && isset($quiz_type))
message_die(GENERAL_MESSAGE, $lang['Quiz_no_number_chosen']);
if(!isset($HTTP_POST_VARS['type']))
$page_title = $lang['Submit_quiz'];
$template->set_filenames(array("add_initial" => 'quiz_add_initial_body.tpl'));
if( $quiz_questions_explode[0] == $quiz_questions_explode[1] )
$quiz_min_max_questions_set = sprintf($lang['Quiz_min_max_set'], $quiz_questions_explode[0]);
$quiz_default_number = ' <b>' . intval($quiz_questions_explode[0]) . '</b><input type="hidden" name="Questions_number" value="' . intval($quiz_questions_explode[0]) . '" />';
else
$quiz_min_max_questions_set = sprintf($lang['Quiz_min_max'], $quiz_questions_explode[0], $quiz_questions_explode[1]);
$quiz_default_number = ' <input type="text" class="post" name="Questions_number" size="5" maxlength="4" value="" />';
$template->assign_vars(array(
"U_DEFAULT" => $quiz_default_number,
"F_FORM" => append_sid("quiz.$phpEx?mode=add"),
"L_MIN_MAX" => $quiz_min_max_questions_set,
"L_SETUP_OPTIONS" => $lang['Quiz_set_up_options'],
"L_SELECT_NUMBER" => $lang['Quiz_select_number'],
"L_TRUE_FALSE" => $lang['Submit_true_false_quiz'],
"L_MULTIPLE_CHOICE" => $lang['Submit_multiple_choice_quiz'],
"L_INPUT" => $lang['Submit_input_quiz'],
$template->pparse("add_initial");
if($quiz_type == 'multiple_choice')
$page_title = $lang['Submit_multiple_choice_quiz'];
quiz_check_question_limitations();
$template->set_filenames(array("multiple_choice" => "quiz_add_multiple_choice_body.tpl"));
for ( $i = 0; $i < intval($HTTP_POST_VARS['Questions_number']); $i++ )
$template->assign_block_vars('question_number', array(
'U_UNIQUE' => $i));
// To make the box..
$category_drop_down_box = '<select name="category">';
$category_sql = "SELECT * FROM " . QUIZ_CATEGORY_TABLE . " ORDER BY category_id ASC";
if(!$category_result = $db->sql_query($category_sql))
message_die(GENERAL_ERROR, '', 'Could not fetch category names!');
while($category_row = $db->sql_fetchrow($category_result))
$category_drop_down_box .= populate_quiz_drop_down_box($category_row['category_id'], $category_row['category_name']);
$category_drop_down_box .= '</select>';
"F_FORM" => append_sid("quiz.$phpEx?mode=sql"),
"U_TOTAL" => intval($HTTP_POST_VARS['Questions_number']),
"U_CATEGORY" => $category_drop_down_box,
"L_INSERT_NAME" => $lang['Quiz_insert_name'],
"L_QUESTION" => $lang['Quiz_question'],
"L_ALTERNATE_ANSWER" => $lang['Quiz_alternate'],
$template->pparse("multiple_choice");
if($quiz_type == 'input_answer')
$page_title = $lang['Submit_input_quiz'];
$template->set_filenames(array("input" => "quiz_add_input_body.tpl"));
'U_UNIQUE' => $i));
"L_CORRECT_ANSWER" => $lang['Quiz_answer_correct'],
$template->pparse("input");
if($quiz_type == 'true_false')
$page_title = $lang['Submit_true_false_quiz'];
$template->set_filenames(array("true_false" => "quiz_add_true_false_body.tpl"));
'U_UNIQUE' => $i));
$template->pparse("true_false");
if($mode == "sql")
// Similar to that of v1.0.x but not the same
// This is better :-)
if($HTTP_POST_VARS['Quiz_Type'] == "Input" || $HTTP_POST_VARS['Quiz_Type'] == "True_False")
if($HTTP_POST_VARS['Quiz_Type'] == "Input")
$table_name = QUIZ_INPUT_TABLE; // x_quiz_input_data
else
$table_name = QUIZ_TRUE_FALSE_TABLE; // x_quiz_true_false_data
for ( $i = 0; $i < intval($HTTP_POST_VARS['Quiz_Question']); $i++ )
$question_sql = "INSERT INTO " . $table_name . " (quiz_id, question_id, quiz_question, quiz_answer)
VALUES ( " . next_quiz_id() . ", " . ($i + 1) . ", '" . str_replace("\'", "''", bbencode_first_pass(htmlspecialchars($HTTP_POST_VARS["Question_$i"]), '')) . "',
'" . str_replace("\'", "''", bbencode_first_pass(htmlspecialchars($HTTP_POST_VARS["Correct_Answer_$i"]), '')) . "')";
if( !$question_result = $db->sql_query($question_sql))
message_die(GENERAL_ERROR, 'Could not insert question / answer data', '', __LINE__, __FILE__, $question_sql);
if($HTTP_POST_VARS['Quiz_Type'] == "Multiple")
// The answer isn't going to be Alternate_x_x now is it :roll:
// Well not often anyway ;-)
// Update: A few months later, I don't even know what the hell I was talking about. Better read the code to find out what exactly this section does eh?
$answer = array();
if($HTTP_POST_VARS["Correct_Answer_$i"] == "Alternate1_$i")
$answer[$i] = bbencode_first_pass(str_replace("\'", "''", $HTTP_POST_VARS["Alternate1_$i"]), '');
else if($HTTP_POST_VARS["Correct_Answer_$i"] == "Alternate2_$i")
$answer[$i] = bbencode_first_pass(str_replace("\'", "''", $HTTP_POST_VARS["Alternate2_$i"]), '');
else if($HTTP_POST_VARS["Correct_Answer_$i"] == "Alternate3_$i")
$answer[$i] = bbencode_first_pass(str_replace("\'", "''", $HTTP_POST_VARS["Alternate3_$i"]), '');
else if($HTTP_POST_VARS["Correct_Answer_$i"] == "Alternate4_$i")
$answer[$i] = bbencode_first_pass(str_replace("\'", "''", $HTTP_POST_VARS["Alternate4_$i"]), '');
// As much as I hate the following few lines, because it is awfully messy, I must say, it works beautifully
// Basically this is the most effective way of doing it. You can use the | but that means that anyone that uses that screws up the quiz.
// Sure the same thing can happen with !*-.@.-*! but what are the odds?
$question_sql = "INSERT INTO " . QUIZ_MULTIPLE_CHOICE_TABLE . "
(quiz_id, question_id, quiz_question, quiz_alternates, quiz_answer)
'" . str_replace("\'", "''", htmlspecialchars($HTTP_POST_VARS["Alternate1_$i"])) . "!*-.@.-*!" . str_replace("\'", "''", htmlspecialchars($HTTP_POST_VARS["Alternate2_$i"])) . "!*-.@.-*!" . str_replace("\'", "''", htmlspecialchars($HTTP_POST_VARS["Alternate3_$i"])) . "!*-.@.-*!" . str_replace("\'", "''", htmlspecialchars($HTTP_POST_VARS["Alternate4_$i"])) . "',
'" . htmlspecialchars($answer[$i]) . "')";
if($HTTP_POST_VARS['Quiz_Type'] == "True_False")
$ultimate_quiz_type = TRUE_FALSE;
else if($HTTP_POST_VARS['Quiz_Type'] == "Multiple")
$ultimate_quiz_type = MULTIPLE_CHOICE;
else if($HTTP_POST_VARS['Quiz_Type'] == "Input")
$ultimate_quiz_type = INPUT_ANSWER;
$sql = "INSERT INTO " . QUIZ_GENERAL_TABLE . " (quiz_id, quiz_name, quiz_author, quiz_category, quiz_type) VALUES (
'" . str_replace("\'", "''", htmlspecialchars($HTTP_POST_VARS['Quiz_Name'])) . "',
'" . $userdata['user_id'] . "',
'" . intval($HTTP_POST_VARS['category']) . "',
'" . $ultimate_quiz_type . "')";
if( !$result = $db->sql_query($sql))
message_die(GENERAL_ERROR, 'Could not insert basic quiz details', '', __LINE__, __FILE__, $sql);
else
message_die(GENERAL_MESSAGE, $lang['Quiz_added_successfully']);
if($mode == "results")
$page_title = $lang['Quiz_score'];
$template->set_filenames(array("quiz_result" => 'quiz_result_body.tpl'));
$id = intval($HTTP_POST_VARS['id']);
if( quiz_check_moderative_status($userdata['user_id'], $id) != ON && $userdata['user_level'] != ADMIN )
$statistics_check = "SELECT * FROM " . QUIZ_STATISTICS_TABLE . " WHERE quiz_id = '$id' AND user_id = '" . $userdata['user_id'] . "'";
$table = QUIZ_INPUT_TABLE;
else if($type == "true_false")
$table = QUIZ_TRUE_FALSE_TABLE;
else if($type == "multiple_choice")
$table = QUIZ_MULTIPLE_CHOICE_TABLE;
$number_of_questions = number_of_questions($id, $table);
$time_taken_to_complete_quiz = time() - intval($HTTP_POST_VARS['f_time']);
$seconds_taken_to_complete_quiz = $time_taken_to_complete_quiz % 60;
$minutes_taken_to_complete_quiz = ($time_taken_to_complete_quiz - $seconds_taken_to_complete_quiz) / 60;
if( $board_config['Quiz_timeout'] != 0 )
if( $time_taken_to_complete_quiz > ($board_config['Quiz_timeout'] * $number_of_questions) )
message_die(GENERAL_MESSAGE, $lang['Quiz_user_exceed_timelimit']);
for ( $i = 0; $i < $number_of_questions; $i++ )
$sql = "SELECT quiz_question FROM " . $table . " WHERE question_id = " . ($i + 1) . " AND quiz_id = " . $id;
message_die(GENERAL_ERROR, '', 'Could not get question', __LINE__, __FILE__);
// Fixed in 1.3.0: All errors with " and inverted commas. I think htmlspecialchars is to blame for this.
$question = smilies_pass(bbencode_second_pass($row['quiz_question'], ''));
$user_answer = str_replace("\'", "'", str_replace('\"', '"', $HTTP_POST_VARS['uqm' . ($i + 1)])); // Changed in 1.3.1. Added letters uqm to overcome PHP bug. Thanks to Xore (MOD Team Member) for pointing this out.
$actual_answer = str_replace('"', '"', htmlspecialchars(quiz_answer(($i + 1), $id, $table)));
if(strtolower($user_answer) == strtolower($actual_answer))
$correct[$i] = 1;
$incorrect[$i] = 0;
// The message consists of Question: Your Answer: Actual Answer
$status = sprintf($lang['Quiz_answer_status'], $user_answer, $actual_answer);
else if(strtolower($user_answer) != strtolower($actual_answer))
$correct[$i] = 0;
$incorrect[$i] = 1;
if($board_config['Quiz_show_answers'] == ON)
$template->assign_block_vars("answer_row", array(
"U_STATUS" => $status,
"U_QUESTION" => $question));
// Get percentage
if ( @array_sum($correct) != 0 && @array_sum($incorrect) != 0 )
if( @array_sum($incorrect) == @array_sum($correct) )
$percentage = '50';
else
$percentage = ( @array_sum($correct) / ( @array_sum($correct) + @array_sum($incorrect) ) ) * 100;
else
if( @array_sum($incorrect) == '0' )
$percentage = '100';
else if( @array_sum($correct) == '0' )
$percentage = '0';
$update_play = "UPDATE " . QUIZ_GENERAL_TABLE . " SET quiz_plays = quiz_plays + 1 WHERE quiz_id = $id";
if( !$db->sql_query($update_play) )
message_die(GENERAL_ERROR, 'Could not update play counter', '', __LINE__, __FILE__, $update_play);
$percentage = number_format($percentage, 0);
"U_CORRECT_SCORE" => sprintf($lang['Quiz_show_correct_score'], @array_sum($correct)),
"U_INCORRECT_SCORE" => sprintf($lang['Quiz_show_incorrect_score'], @array_sum($incorrect)),
"U_PERCENTAGE" => $percentage . '%',
"L_TIME_TAKEN" => sprintf($lang['Quiz_user_time_taken_quiz'], $minutes_taken_to_complete_quiz, $seconds_taken_to_complete_quiz),
"L_RETURN_INDEX" => sprintf($lang['Click_return_index'], '<a href="' . append_sid("index.$phpEx") . '">', '</a>'),
"L_RETURN_QUIZ" => sprintf($lang['Quiz_click_return_quiz'], '<a href="' . append_sid("quiz.$phpEx") . '">', '</a>'),
"L_ANSWERS" => $lang['Quiz_score']));
$statistics_sql = "INSERT INTO " . QUIZ_STATISTICS_TABLE . " (stats_id, quiz_id, user_id, stats_correct, stats_incorrect, stats_percentage) VALUES ('" . quiz_new_stats_id() . "', '$id', '" . $userdata['user_id'] . "', '" . @array_sum($correct) . "', '" . @array_sum($incorrect) . "', '$percentage')";
if(!$db->sql_query($statistics_sql))
message_die(GENERAL_ERROR, '', 'Could not insert statistical values', __LINE__, __FILE__, $statistics_sql);
// Let's do the cash
if( $board_config['Quiz_CashMOD_On'] == ON )
include($phpbb_root_path . 'includes/functions_cash.'.$phpEx);
// Lets get the currency.. err... name?
$get_cash_name = "SELECT cash_name FROM " . CASH_TABLE . " WHERE cash_dbfield = '" . $board_config['Quiz_Cash_Currency'] . "'";
if( !$get_cash_result = $db->sql_query($get_cash_name) )
message_die(GENERAL_ERROR, 'Unable to execute cash name query', '', __LINE__, __FILE__, $get_cash_name);
$actual_cash_name = $db->sql_fetchrow($get_cash_result);
$cash_per_correct = $board_config['Quiz_Cash_Correct'];
$cash_per_incorrect = $board_config['Quiz_Cash_Incorrect'];
$cash_tax = $board_config['Quiz_Cash_Tax'];
$total_cash = ( ( @array_sum($correct) * $cash_per_correct ) - ( @array_sum($incorrect) * $cash_per_incorrect ) - ( $cash_tax ) );
if( $total_cash > 0 || $total_cash == 0 )
$cash_language_variable = sprintf($lang['Quiz_cash_total_result_gain'], $total_cash, $actual_cash_name['cash_name']);
$cash_sql = "UPDATE " . USERS_TABLE . " SET " . $board_config['Quiz_Cash_Currency'] . " = " . $board_config['Quiz_Cash_Currency'] . " + " . intval($total_cash) . " WHERE user_id = " . $userdata['user_id'];
else if( $total_cash < 0 )
$total_cash = str_replace('-', '', $total_cash);
$cash_language_variable = sprintf($lang['Quiz_cash_total_result_loss'], $total_cash, $actual_cash_name['cash_name']);
$cash_sql = "UPDATE " . USERS_TABLE . " SET " . $board_config['Quiz_Cash_Currency'] . " = " . $board_config['Quiz_Cash_Currency'] . " - " . intval($total_cash) . " WHERE user_id = " . $userdata['user_id'];
if( !$db->sql_query($cash_sql) )
message_die(GENERAL_ERROR, 'Unable to execute cash update', '', __LINE__, __FILE__, $cash_sql);
$template->assign_block_vars('cash_row', array());
$template->assign_vars(array("U_CASH" => $cash_language_variable));
$template->pparse("quiz_result");
$page_title = $lang['Quiz_quizzes'];
$template->set_filenames(array("quiz_index" => "quiz_index_body.tpl"));
$sql_suffix = "WHERE category_permissions = 0 OR category_permissions = 1";
else
$sql_suffix = '';
$sql = "SELECT * FROM " . QUIZ_CATEGORY_TABLE . " $sql_suffix";
message_die(GENERAL_ERROR, '', 'Could not obtain quiz category data', __LINE__, __FILE__);
$category_id = intval($row['category_id']);
$category_name = str_replace("\'", "''", $row['category_name']);
$category_description = str_replace("\'", "''", $row['category_description']);
$category_quizzes = category_quizzes($category_id);
"U_NAME" => "<a href='" . append_sid("quiz.$phpEx?" . POST_CAT_URL . "=$category_id") . "'>$category_name</a>",
"U_DESCRIPTION" => $category_description,
"U_QUIZZES" => $category_quizzes . ' ' . $lang['Quiz_quizzes']));
"L_QUIZZES" => ( $board_config['Quiz_timeout'] == 0 ) ? $lang['Quiz_quizzes'] : sprintf($lang['Quiz_user_time_on_index'], $board_config['Quiz_timeout']),
// Just noticed that there are 971 line so far, can we make 1000? Yep
$quiz_cash_correct = intval($board_config['Quiz_Cash_Correct']);
$quiz_cash_incorrect = intval($board_config['Quiz_Cash_Incorrect']);
$quiz_cash_tax = intval($board_config['Quiz_Cash_Tax']);
"CASH_INFORMATION" => sprintf($lang['Quiz_cash_information'], $quiz_cash_correct, $quiz_cash_incorrect, $quiz_cash_tax)));
// I'm now depressed, that was the first time this series I haven't labelled it L_, U_, or F_. Pfft
$template->pparse("quiz_index");
i can't find the file that you were asking under templates/admin directory, please refer to the image below.
