Windows Vista Boot Configuration Data (BCD) Edit Made Easy
Posted: Sat Jul 28, 2007 6:32 am
http://www.pcworld.com/article/id,13004 ... ticle.html
PC World's 101 Fantastic Freebies List.Why VistaBootPRO?
Chances are you're here because you're running Windows Vista and want to do one of two things. Install a second OS or manage your boot configuration without directly editing the BCDEdit file. As you likely now realize, Windows Vista has made this task somewhat complicated for most users. VistaBootPRO was developed to make changes to the Windows Vista Boot Configuration Data (BCD) registry quickly and easily, doing the job in a fraction of the time it would take using the alternative. The only other way to edit the BCD is to use the command prompt application "bcdedit.exe," located in the Windows\system32 folder of Windows Vista, which requires users to become familiar with the ins and outs of the bcdedit.exe switches and options, leaving many frustrated users in its path. VistaBootPRO allows users to easily and neatly organize their boot configuration entries from within all flavors of Windows.
With a total worldwide distribution of over half a million downloads, VistaBootPRO has proven to be an indispensible utility for the Vista enthusiast, and was recently named to PC World's "101 Fantastic Freebies" list.
System Requirements: Windows XP (Home, PRO, x64, MCE 2005), 2003 Server, Vista, or Longhorn Server. All systems must have .NET 2.0 Framework
* Date Released: Friday April 27, 2007
* File Name: VistaBootPRO_3.3.0.exe
* MD5 Sum: 13DA6433953183268F189A5B682926FF
* SHA-1 Hash: 12E3A36C0C758E60DAFBD822B45A7F4EEDF89AD0
* Digital Signature: Hawaiian Style Organization LLC.
* VeriSign Timestamp: Monday, May 28, 2007 1:18:32 PM
* File size: 1.59 MB (1,669,368 bytes)
* Download Time: @ 28k Modem is ~6 minutes | 56k Modem is ~3 minutes | DSL (1.5Mbps) Less then a minute
* Additional Resources: Online Tech Support
* View our change log from older versions.
* View Screenshots
* *Advisory: It is highly encouraged that all user's make a backup of the BCD store using the backup option in VistaBootPRO 3.3
http://www.vistabootpro.org/
