Page 2 of 2
Posted: Fri Jul 14, 2006 2:21 am
That's impossible.. did you also change the one on line 290 as mentioned in the error?
Posted: Fri Jul 14, 2006 5:01 am
by Heeter
Hi Battye,
I searched through that area on the index.php. I did not locate that text.
I cleaned all my forums files out and did a fresh install with 2.0.19. then I imported my backup config.php and my backups and started from fresh. Will do a Shoutbox Mod from fresh as well.
The site is up again, and I didn't lose any posts/threads.
Thanks Battye, for sticking with me. Looking forward to installing 0.1.3 as I have been using 0.1.2 up until now.
What is the difference?
Thanks,
Heeter
Posted: Fri Jul 14, 2006 5:17 am
Hi, there is someone who made 0.1.4 (at phpBB.com) so you may want to consider that instead
Hope to continue to see you around the forums here
If you get a chance, don't forget to drop by OT Forum
Posted: Fri Jul 14, 2006 6:35 pm
by Heeter
Sure I am sticking around, The yellow paint in here is pretty cool, LOLOL
Is there a way do remove/clean out the shoutbox entries in mysql (4.1.2 version).
I am still getting sql errors same as posted above when I run shoutbox_install.
Will go check for updated version of Shoutbox. Excited already. I never really modded my site, really not into it, but the Shoutbox mod is the only one that everyone sees/uses, can't wait to get it going.
Thanks Battye.
Heeter
