WinMX Group's WinMX .DLL Patch
Quoted from WinMX group
If you downloaded the patch before 10/10/05 then please download it again, a bug fix has been released.
Known "Issues" - READ THIS FIRST
Windows 98/ME Users. Please be aware that this does not seem to function on these operating systems yet. I am working on resolving this issue.
If you have BendMX or RCMS then DO NOT replace BendMX/RCMS with this patch or it will replace BenxMD/RCMS! Instead replace the file named WS2_32o.dll for RCMS or WS2_32r.dll for BendMX!
Users of WinMX 3.53 using the "olepro32.dll" channel list patch, some users have reported conflicts beteen the 2 patches (while a couple have said it works fine). If you do suffer problems then try removing the "olepro32.dll" patch.
Download a patch to get your WinMX working!
Just put the patch in your WinMX directory and WinMX will function properly.
If you have issues with this patch then try version 1.0 or version 1.1
Check Peer Caches
Thanks to KM & WinMx Group. :D
For people using 98/ME OS you can try the WinMX World's 98/ME hosts patch or Vladd44's hosts patchPIEPatch.
:arrow: Download WinMX World's
98/ME Patch Automatic Installer.
:arrow: download Vladd44's PIEPatch Automatic InstallerPIEPatch v2.6 or the manual install PIEPatch v2.6.
Thanks to WinMX World & Vladd44. :D
Last edited by p2p-sharing-rules on Tue Sep 18, 2007 9:24 pm, edited 1 time in total.
From WinMX World:
The Patch for 98/ME users is finally here. This new updated Patch works beautifully with all operating systems. This is NOT a hosts file, and will allow you to have the same speeds with connection as the .dll has for XP/2000 users.
Just follow the instructions that go along with this installation as you go. and restart WinMX...
Keep in mind that this .DLL for 98/ME has no block list function and all primary users on those systems should be using Sherwood, found in our forum under Other Software..
or use Peerguardian.
:arrow: Download Install-1.9.exe or from here.
Thanks to KM, Me Here, WinMX World & WinMX Group:D :D
Me Here from WMW wrote :
If your using our hosts file on your XP/2000 system it was updated
Oct 15th 2005 at 03:40 GMT
It is strongly advised that if your using and old form of ANY HOSTS files that you update them respectively..
Self Installing for WIndows XP/2K
hosts_file_xp-2k.exe
The installer for 98/ME systems
hosts_file_98me.exe
Manual Install
winmxworld_hosts.zip
Thanks to Me Here & winxmworld.
:D
Stickied
Update Install-2.0
KM wrote:
the major change is that it now gets the block list from the peer cache rather than the web server (meaning much less code for downloading the list, meaning less potential for bugs! yay) and both versions of the patch now include the block list (although only the ws2_32.dll version loads the web page in the corner to notify of updates etc) - also modified the installer a little so it is now labeled 3.54 and 3.53 instead of NT and 9x, and it selects 3.53 for XP SP2 users with IE7 (which seems to cause problems with the 3.54 version)
Download install-2.0 with WinMX.
Download Install-2.0 only.
Thanks to KM , winmxworld & winmxgroup!! :D
New update Install-2.2
Install-2.2 with WinMX
Install-2.2 without WinMX
Thanks to KM, winmxworld & winmxgroup. :D
