KTorrent
KTorrent is a BitTorrent program for KDE. The current release is 2.0.1 which is a bug fix release for the 2.0 release. The 2.0 release adds several big new features to KTorrent :
* Support for distributed hash tables (mainline version)
* Protocol encryption
* Bandwith scheduling
* Directory scanner to automatically load torrents in certain directories
* Trackers can now be added to torrents
* File prioritization for multi file torrents
And of course a whole bunch of bug fixes. We allready supported the following features in the previous version :
* Downloads torrent files
* Upload and download speed capping
* Internet searching using various search engines, you can even add your own
* UDP Trackers
* Port forwarding with UPnP
* IP blocking plugin
* Importing of partially or fully downloaded files
It has only been tested on linux at the moment, but it should work on most, if not all unix platforms. The latest stable version of ktorrent is 2.0.1 and it's released under the GNU GPL License.
KTorrent
- p2p-sharing-rules
- Moderator
The current release is 2.0.2 which is the second bug fix release for the 2.0 release.
- p2p-sharing-rules
- Moderator
The current release is 2.0.3 which is the second bug fix release for the 2.0 release.
- p2p-sharing-rules
- Moderator
The current release is 2.1rc1 which is the second release on the way to the final 2.1 release
New features added since 2.0.3 :
* µTorrent compatible peer exchange
* Zeroconf extension to find peers on the local network
* Switched the GUI to an IDEAl style GUI (like KDevelop)
* WebGUI plugin
* RSS plugin
* Improvements in down and upload performance
* Grouping feature to put torrents into groups
* Improved search plugin, which now allows multiple searches
* Many bug fixes
Downloads
KTorrent 2.1rc1
Source code : ktorrent-2.1rc1.tar.gz
Arch Linux : ktorrent-2.1rc1-1.pkg.tar.gz
* WebGUI plugin
* RSS plugin
* Many bug fixes
Downloads
KTorrent 2.1rc1
- p2p-sharing-rules
- Moderator
KTorrent is a BitTorrent program for KDE. The current release is 2.1.2. New features added since 2.0.3 :
* WebGUI plugin
* RSS plugin
* Many bug fixes
Last edited by p2p-sharing-rules on Wed Apr 04, 2007 9:42 pm, edited 2 times in total.
- p2p-sharing-rules
- Moderator
KTorrent is a BitTorrent program for KDE. The current release is 2.1.3. New features added since 2.0.3 :
* WebGUI plugin
* RSS plugin
* Many bug fixes
This is a bug fix release, it fixes a crash in the 2.1.2 release. People experiencing the crash should upgrade.
- p2p-sharing-rules
- Moderator
KTorrent updated to version 2.1.4.
*Removed non working download links.*This is a bugfix release, and contains some minor bug fixes, most notably the .. problem in filenames.
People experiencing the DHT crash, should also upgrade.
If you run Kubuntu you'll have KTorrent installed by default. Also, for those looking for a Linux distro to try for the first time, Kubuntu provides a pretty familiar environment.
It's also in mandriva - if you select internet or multimedia as the type of station when you install the OS. Anyways... its on the DVD so you can always add it if you don't get it installed automatically.
- p2p-sharing-rules
- Moderator
The lastest version of KTorrent v2.2.2.
- p2p-sharing-rules
- Moderator
KTorrent 2.2.3 is out
This release contains all the bugfixes from the last few months and a couple of new features, like the filterbar (hit CTRL+F and you can filter out torrents) and the possibility to manage the files of a torrent via the default webgui.
- p2p-sharing-rules
- Moderator
KTorrent 2.2.4 is out, this fixes a crash in 2.2.3 and some other minor stuff. There are also some improvements made to the webgui.
* Fixed crash in fileview
* Added patch from Rafel Milecki to add file selection in the coldmilk webgui
* Added patch from Rafel Milecki to add a confirmation dialog when the user shutsdown KT in the default webgui
* Fixed bug which caused the set max rate menu in the system tray icon menu to fail in recent KDE versions
* Optimized SHA1 hash generation a bit
Download link Source code : ktorrent-2.2.4.tar.gz
Link for OpenSUSE versions: 10.2 and 10.3
It may have been fixed, but I run into issues with KTorrent 2.1.4 where it seems to hang after any error. If it times out it will wait days for me to find out and click OK before it continues downloading.
I've been using a console program called btdownload-curses
I check it remotely through ssh, which is much faster than vnc when all of your bandwidth is going to a torrent.
- p2p-sharing-rules
- Moderator
nesman, they have a new beta version out if you want to try it.
KTorrent 3.0beta1 can be found on the downloads page at the bottom of the page.
I'll be posting about the final release when it's out of beta testing on here.
- p2p-sharing-rules
- Moderator
Both KT 2.2.5 and 3.0rc1 have been released. 2.2.5 is the next bugfix release for the 2.2 series, it contains all the bugfixes done in the last month since the 2.2.4 release.
3.0rc1 is the next step on the way to the final 3.0 release, it should be a lot better and more stable then the beta release. And it should be ready for day to day use.
Download them here.
Download them here.
