SQL install error
Carinspixels
When I try to run the ult_database or add them manually I get this errors:
INSERT INTO `phpbb_config` VALUES ('questions_quiz', '5'): Installer has encountered an error
INSERT INTO `phpbb_config` VALUES ('quiz_one_category', 'Off'): Installer has encountered an error
INSERT INTO `phpbb_config` VALUES ('quiz_cash_on', 'Off'): Installer has encountered an error
INSERT INTO `phpbb_config` VALUES ('quiz_verify', 'Off'): Installer has encountered an error
INSERT INTO `phpbb_config` VALUES ('quiz_cost', '5'): Installer has encountered an error
INSERT INTO `phpbb_config` VALUES ('quiz_cash_field', 'user_points'): Installer has encountered an error
INSERT INTO `phpbb_config` VALUES ('quiz_cash_wrong', '10'): Installer has encountered an error
INSERT INTO `phpbb_config` VALUES ('quiz_cash_correct', '25'): Installer has encountered an error
INSERT INTO `phpbb_config` VALUES ('quiz_admin_submit', 'Off'): Installer has encountered an error
INSERT INTO `phpbb_config` VALUES ('quiz_play_once', 'Off'): Installer has encountered an error
INSERT INTO `phpbb_config` VALUES ('quiz_guest', 'Off'): Installer has encountered an error
INSERT INTO `phpbb_config` VALUES ('quiz_time_limit', 'Off'): Installer has encountered an error
INSERT INTO `phpbb_config` VALUES ('quiz_time', '10'): Installer has encountered an error
INSERT INTO `phpbb_config` VALUES ('quiz_survey', 'Off'): Installer has encountered an error
INSERT INTO `phpbb_config` VALUES ('quiz_mod_edit', 'On'): Installer has encountered an error
INSERT INTO `phpbb_config` VALUES ('quiz_minimum_posts', '0'): Installer has encountered an error
So basicly it isnt working for me, any tips???
Do you have Categories Hierachy, looks like a classic CH problem.
Carinspixels
battye wrote:Do you have Categories Hierachy, looks like a classic CH problem.
I dont use the Categorie hierarchy and haven't got it installed either, I've seen the link in the readme file to that problem to fix so i'm gonna try to see if that works ;)
Thanks for your reply!
Carinspixels
okay that worked like a charm, but now.....
I have another small problem
Carinspixels wrote:okay that worked like a charm, but now.....
Glad you got that working, was probably something else in the phpBB config table causing the problem, so the CH fix would have indeed worked.
What is the other problem? :)
Carinspixels
got that figured out allready, thanks so much!
the members so love it!
Glad you (and your members) like it :D
