Sorry to bother you again with RoboMX lol
RoboMX 1.31 Beta 1
Download:
http://mxcontrol.sf.net/roboServ/RoboMX.exe
(you need the full version of RoboMX 1.25 to run this aswell, you can get it from the download section. Replace the RoboMX.exe with this one.)
Changes in RoboMX 1.31 Beta 1
- Rewrote wide parts of the chatclient for better WinMX compability
- Fixed problems in WinMX 3.53 rooms with RCMS
- Fixed problems in roboServe rooms
- Cleaned up settings dialog
- Fixed several bugs in the settings dialog
- Fixed bugs in plugin loader
- Fixed bugs in the channellist
- Added option to only cache favorite rooms across sessions instead of all rooms (this is the default now)
- Clear channels and Clear refresh buttons now wont clear the favorites from the list
- Fixed several bugs in operator message handling
- Fixed several bugs related to rooms with colored text support
- Added function to correctly map colored names to the real username (yet to be tested)
- Fixed loop problem in Private message window
- Fixed possible racing condition on shutdown
- Changed default color-scheme to WinMX lighttext/dark background
- Added colored texttrick
- Added statistic command (F7)
Have fun!
