UniForm Server
Grinch
Turn your home PC into a fully functional server complete with:
PHP5, MySQL, Apache and PHPMyAdmin :D
As soon as it is installed you are ready to go. You do need to do some configuring to get available to other people but it is fairly straight forward (even I figured it out without asking questions).
This is a handy tool for those PHP developers to test their stuff out without uploading to their webhost. Also good for people who want to learn how to code PHP, set up a forum or..... gasp.... a BT Tracker :-***) . I have learned a lot messing around with UniServer and other programs like it.
There is a support forum for this proggie but they are kind of slow to respond.
http://miniserver.sourceforge.net/
Sounds very useful Grinch , much easier to iron out bugs and links off line. 8)
As its hosted on sourceforge I take it, its open source ?
Grinch
I would say yes
I've been using this for a while, very handy. However to avoid problems occuring with older programs it's best to download UniForm server with PHP 4.x. Or in php.ini alter the configuration setting of register_long_array :)
I'm just bumping this so I can find it later. I might try to forward a port or two to my laptop because when I lose access to my server, I don't know if my cable went out, or if I need to call home and have somebody restart it. :)
Layzie is probably interested in this too.
