Energy Hogs & Bugs - Apps That Sap
Carat
Carat is a free app that tells you what is using up the battery of your mobile device, whether that's normal, and what you can do about it. After running Carat for about a week, you will start to receive personalized recommendations for improving your battery life. Carat is a research project based out of the AMP Lab in the EECS Department at UC Berkeley, collaborating with the University of Helsinki
http://carat.cs.berkeley.edu/
Just seeing if I can get rid of the bot's name, I've deleted the post but the name has remained for some reason.
I am hoping that this post will remove the bot name from the list :evil:
That worked, now out of curiosity, if I delete this post will the bot name return?
No it didn't :)
