Here is just a little information so you know how I have things setup. When you go too my websites homepage, the index.php files looks like this
ob_start ("ob_gzhandler");
include($_SERVER['DOCUMENT_ROOT'] . "/templates/site_header.php");
include($_SERVER['DOCUMENT_ROOT'] . "/news.php");
include($_SERVER['DOCUMENT_ROOT'] . "/templates/site_footer.php");
?>The news.php looks like this
* home.php
* September 29, 2009
$phpbb_root_path = (defined('PHPBB_ROOT_PATH')) ? PHPBB_ROOT_PATH : './forums/';
$user->session_begin();
$auth->acl($user->data);
$user->setup('viewforum');
* posts and topics */
global $db, $auth;
switch($type)
case 'forum':
$type = 'forum_id';
break;
case 'topic':
$type = 'topic_id';
break;
default:
// no restrictions
$out_where = '';
if ($size_gen_id > 0)
if ($type == 'topic_id')
$sql = 'SELECT topic_id FROM ' . TOPICS_TABLE . '
WHERE ' . $db->sql_in_set('topic_id', $gen_id) . '
AND ' . $db->sql_in_set('forum_id', $auth_f_read);
unset($gen_id);
$gen_id = $topic_id_list;
$j = 0;
for ($i = 0; $i < $size_gen_id; $i++)
$id_check = (int) $gen_id[$i]; // If the type is topic, all checks have been made and the query can start to be built if( $type == 'topic_id' ) { $out_where .= ($j == 0) ? 'WHERE ' . $type . ' = ' . $id_check . ' ' : 'OR ' . $type . ' = ' . $id_check . ' '; } // If the type is forum, do the check to make sure the user has read permissions else if( $type == 'forum_id' && $auth->acl_get('f_read', $id_check) )
$j++;
if ($out_where == '' && $size_gen_id > 0)
return $out_where;
$search_limit = 5;
$forum_id = array(16);
$posts_ary = array(
'SELECT' => 'p.*, t.*',
'FROM' => array(
POSTS_TABLE => 'p',
'LEFT_JOIN' => array(
array(
'FROM' => array(TOPICS_TABLE => 't'),
'ON' => 't.topic_first_post_id = p.post_id'
'WHERE' => str_replace( array('WHERE ', 'forum_id'), array('', 't.forum_id'), $forum_id_where) . '
AND t.topic_approved = 1',
'ORDER_BY' => 'p.post_id DESC',
while ($posts_row = $db->sql_fetchrow($posts_result))
$topic_title = $posts_row['topic_title'];
$topic_author = get_username_string('full', $posts_row['topic_poster'], $posts_row['topic_first_poster_name'], $posts_row['topic_first_poster_colour']);
$topic_date = $user->format_date($posts_row['topic_time']);
$topic_link = append_sid("{$phpbb_root_path}viewtopic.$phpEx", "t=" . $posts_row['topic_id']);
'TOPIC_TITLE' => censor_text($topic_title),
'TOPIC_AUTHOR' => $topic_author,
'TOPIC_DATE' => $topic_date,
'TOPIC_LINK' => $topic_link,
'POST_TEXT' => censor_text($post_text),
'body' => 'site_news.html'
page_footer();
?>I have noticed a previous topic discussing this issue. I have tried your solution for the problem which you gave in that topic with no luck. I understand that your time is very precious and any help you can give me is very much appreciated. Thank you for taking the time and reading my issue, I hope to hear back from you soon. In the mean time, I will continue to try and solve this problem.
