UQM - How to add "new quiz" icon for Category view page
quahappy
Happy, not Quappy
Happy, not Quappy
This suggestion was originally here.
At the moment, if on viewing a list of quizzes within a category and new quiz(zes) has been added, the "new quiz" icon is shown.
It would be excellent if the "new posts" image on forum index could be included on the "Select category" page so users can see that one category (or more) contain new quizzes. If no new quiz within a category then you see "no new posts" image. Or, if possible, custom UQM "new quiz/no new quiz" images. I could create these if demand calls for this. ;)
Try this quahappy, let me know if it works. Don't forget to purge cache afterwards :)
OPEN quiz.php
				$quiz_count_quiz_num	= find_number_of_quiz_in_category($quiz_category_id);
AFTER ADD
				$new_quiz_sql = 'SELECT COUNT(quiz_id) AS qct FROM ' . QUIZ_TABLE . '
								 WHERE quiz_category = ' . $quiz_category_id . '
								 AND quiz_date > ' . $user->data['user_lastvisit'];
				$new_quiz_result = $db->sql_query($new_quiz_sql);
				$new_quiz_row = $db->sql_fetchrow($new_quiz_result);
				$new_quiz_login = ($new_quiz_row['qct'] > 0) ? $user->img('icon_topic_newest', 'VIEW_NEWEST_POST') . ' ' : '';
				$db->sql_freeresult($new_quiz_result);
				$template->assign_block_vars('category_row', array(
				'CAT_LINK'				=> $quiz_category_link,
				'CAT_NAME'				=> $quiz_category_name,
AFTER ADD
				'CAT_NEW_QUIZ'				=> $new_quiz_login,
OPEN styles/prosilver/template/quiz_body.html
<dt><label for="keywords"><a href="{category_row.CAT_LINK}">{category_row.CAT_NAME}</a></label>
IN LINE FIND
BEFORE ADD
{category_row.CAT_NEW_QUIZ}
Let me know how that goes :)
quahappy
Happy, not Quappy
Happy, not Quappy
Sorry for taking a while to reply. Been extremely busy of late.
Thanks for the code battye. Will later insert and test later then let you know how it goes. ;)
quahappy
Happy, not Quappy
Happy, not Quappy
Yep. It works. :D
Only thing I notice is when all new quiz(zes) has been played, the {category_row.CAT_NEW_QUIZ} image still shows and only disappears if you log out and back in again unless of course new quizzes has been added since.
