Good to hear battye!
Some ideas:
1. Multiple choice questions:
Ability to choose two to four answers.
2. Time per question:
Ability to choose different time according to Quiz type as Input Answers Quiz require more time over True / False which require a lot less time per question, whereby Multiple Choice a little more than True / False. Example:
True / False: 5 seconds
Multiple Choice: 10 seconds
Input answers: 15 seconds
This would also eliminate possible cheaters (if Quiz play set to once only).
3. Prevent Quiz being able to be restarted:
If Quiz can only be played once (set via UQM ACP), refreshing a Quiz in play, or clicking back in browser then selecting the same quiz results in "You've already attempted to play this Quiz!" message.
4. Extra UQM ACP option:
Ability to select and restrict access of UQM to a Usergroup
5. "Time remaining" displayed:
So Quiz players can see exactly how much time is remaining. Would also be great (if possible) to have the timer displayed at start and end of quiz in play (so no need to scroll back up to check time remaning).
... that's a few but look forward to your list too.
