First, the administrative templates for adding and editing categories.
The problem with the existing ones is that the fields are too small. Definitely too small. So I changed them a little bit so they visually resemble Edit Forum template. This is cosmetic change, no functionality added or removed. Both templates are almost identical.
Here you go:
quiz_add_category_body.tpl
<form action="{F_FORM}" method="post">
<table width="100%" cellpadding="4" cellspacing="1" border="0" class="forumline" align="center">
<tr>
<th class="thHead" colspan="2">{L_ADD}</th>
</tr>
<tr>
<td width="100%" colspan="2" class="row1" align="center" valign="middle" height="100%">
<span class="gen">{L_EXPLAINATION}</span>
</td>
</tr>
<tr>
<td class="row1">{L_NAME}</td>
<td class="row2"><input type="text" size="25" name="name" value="" />
</td>
</tr>
<tr>
<td class="row1">{L_DESCRIPTION}</td>
<td class="row2"><textarea rows="5" cols="45" wrap="virtual" type="text" name="description" value="" /></textarea>
</td>
</tr>
<tr>
<td class="row1">{L_PASSWORD}</td>
<td class="row2"><input type="password" size="25" name="password" value="" />
</td>
</tr>
<tr>
<td class="row1">{L_CHOOSE_PER}</td>
<td class="row2">
<select name="permissions">
<option id="0" value="0">{L_GUEST}</option>
<option id="1" value="1">{L_REG}</option>
<option id="2" value="2">{L_REG_HIDDEN}</option>
</select>
</td>
</td>
</tr>
<tr>
<td class="catBottom" colspan="2" align="center">
<input class="liteoption" type="submit" value="{L_SUBMIT}" />
</td>
</tr>
</table>
</form>Code: Select all
<tr>
<th class="thHead" colspan="2">{L_EDITING}</th>
</tr>
<tr>
</td>
</tr>
<tr>
<td class="row2"><input type="text" size="25" name="name" value="{U_NAME}" />
</td>
</tr>
<tr>
<td class="row2"><textarea rows="5" cols="45" wrap="virtual" type="text" name="description" value="{U_DESCRIPTION}" />{U_DESCRIPTION}</textarea>
</td>
</tr>
<tr>
</td>
</tr>
<tr>
<td class="row2">
</select>
</td>
</td>
</tr>
<tr>
</td>
</tr>
</table>
</form>
