Only quiz moderators can submit quizzes
robdec
Let me start off by saying thanks for such a great mod. I installed this a few days ago and everything works great except one part. No matter who I add to the Quiz Moderator list they can not create quizes. Only site admins can. Am I doing something wrong? I checked the database and the names are in the Quiz moderator table.
kikkotm
you're right...i've the same problem
ImageImage Wine is an enemy of the man... Who escapes in front of the enemy is an ignoble man!!! ImageImage
Image Image
Image Image
Image Image
Image Image
robdec
Glad to see I'm not the only one. Does anyone know of a solution for this. I have searched but didnt see anyone else report it.
Are you entering user id's? Sounds like you might be entering their usernames.
kikkotm
battye wrote:Are you entering user id's? Sounds like you might be entering their usernames.
yeah...i wrote USER1,USER2,USER3...
Yeah, that's the problem. Enter their user id numbers. Like: 4,76,21,53,11,100,21 .... etc
kikkotm
ooooooh ok... perfect... ;)
Image Image
Image Image
Image Image
Image Image
robdec
That fixed it thanks
Fantastic :)
kikkotm
I tried to ban some users to not partecipate to quizzes but it doesn't work.
I insert user's id like 40,34,45..but :(
Image Image
Image Image
Image Image
Image Image
kikkotm wrote:I tried to ban some users to not partecipate to quizzes but it doesn't work.
If you try putting your own user ID in there, what happens when you try to access quizzes?
kikkotm
I tried with an user ID (i was going on phpbb database to search the exactly id)
I write 40 (the number), I tried to acced with the User Numbero 40, but I could do the test. :(
I tried also with 39 (the number on the forum list) but the result was the same!!
Image Image
Image Image
Image Image
Image Image
Try this.
Open functions_quiz.php and FIND:
function quiz_permissions()
global $board_config, $lang, $userdata;
	if($board_config['Quiz_Register_Play'] == ON) // If this is OFF, basically it means Guests can play quizzes.
		if(!$userdata['session_logged_in'])
			return message_die(GENERAL_MESSAGE, $lang['Quiz_must_be_registered']);
	if($board_config['Quiz_Post_Count_Play'] == ON)
		if($userdata['user_posts'] < $board_config['Quiz_Post_Requirement'])
			return message_die(GENERAL_MESSAGE, sprintf($lang['Quiz_post_requirement_not_met'], intval($board_config['Quiz_Post_Requirement'])));
REPLACE WITH
$users = explode(',', $board_config['Quiz_Banned']);
	for( $o = 0; $o < count($users); $o++ )
		if( intval($userdata['user_id']) == intval($users[$o]) )
			message_die(GENERAL_MESSAGE, "You cannot play quizzes");
Does that fix it? :)
kikkotm
U ARE THE BEST!!! :D :D :D
Image Image
Image Image
Image Image
Image Image
