i can't play a quiz with multiple choise anymore, i mean, i can play the quiz but always got the message that the time was up
even when i create a new quiz, and give lots of time for each question, i still have the problem
other type of quizzes are working fine
any ideas ?
Problem
advanced bbcode box mod - who can convert this mod to phpbb ???
when i put the time function back to 0 (disable it), i can play the quiz.
but after the quiz i got the message:
Deze quiz duurde 19707109 minu(u)t(en), 56 seconde(n)
this quiz took 19707109 minutes, 56 seconds
seems quite long for 1 question
quiz mod is getting messed up i think, when i play multiple choise, all the answers are wrong, even when correct ...
think ill have to do reinstall or something
It sounds like maybe when you made one of the edits (such as the red for wrong answer, green for right answer) you accidentally removed an important piece of code.
Have you checked to make sure all edits were made correctly?
jups, everything correct, but ill check it over after work
You could replace the current quiz.php (but back it up first ) with an original quiz.php. That will tell you for sure if the strangeness is a result of a editing mistake
still wrong
Hmm, that certainly is odd.
What is an example quiz?
Just give me the: question, answer, and multiple choices 1 - 3, of any quiz that isn't working.
i created new ones, they are working
but the old ones still are not working, i will erase them, create them again, and check again.
but the new quizzes im adding are working fine now
(got to go to work now )
