An Error Occurred
DEBUG MODE
SQL Error : 1064 You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'WHERE quiz_id = 4' at line 1
Line : 165
File : functions_quiz.php
other quizes work, but for the newest one i had to put max # of questions to 50 so maybe thats a problem?
Ah alright, if you stand up rather than sit down the error will go away
i was taking a quiz and i finnished it, i clicked submit and then this error came up...
Has this ever happened to you before, or does it happen every time you take a quiz? If it happens often, are you sure every table has been created in the database?
the one that doesnt work is Multiple Checkbox Quiz
Don't know what that is, certainly isn't a part of the default package
next time put your right hand in and shake it about, do the hokey pokey and turn yourself around. that should work
Sometimes when you cry... no one sees your tears.
Sometimes when you are worried... no one sees your pain.
Sometimes when you are happy... no one sees your smile.
But fart just one damn time ...
(¯`·._.·[GUEST 601]·._.·´¯)
Multiple Checkbox Quiz sounds like an addon to the Ultimate Quiz MOD. It is quite likely that that is the cause of your problems.
hmmm it seems that i have forgoten to put something into includes/constants.php
muliple checkbox now works but i cant delete quiz with id 4... i had 1 quiz with multiple checkbox that didnt work, then i have deleted it, but it seems that it didnt go form the db, couse next quiz someone submited merged with that deleted one... and now after all that i cant delete that quiz with id 4
