Errors runnign the Quiz Install
VMars
I got the following list of errors when i tried to run the quiz install:
CREATE TABLE phpbb_quiz_statistics ( `stats_id` int(5) NOT NULL default '', `quiz_id` int(10) NOT NULL default '', `user_id` int(10) NOT NULL default '', `stats_correct` INT(5) NOT NULL default '0', `stats_incorrect` INT(5) NOT NULL default '0', `stats_percentage` INT(3) NOT NULL default '0');
CREATE TABLE phpbb_quiz_multiple_choice_data ( `quiz_id` int(10) NOT NULL default '0', `question_id` int(10) NOT NULL default '0', `quiz_question` text NOT NULL, `quiz_alternates` text NOT NULL, `quiz_answer` text NOT NULL);
CREATE TABLE phpbb_quiz_true_false_data ( `quiz_id` int(10) NOT NULL default '0', `question_id` int(10) NOT NULL default '0', `quiz_question` text NOT NULL, `quiz_answer` text NOT NULL);
CREATE TABLE phpbb_quiz_input_data ( `quiz_id` int(10) NOT NULL default '0', `question_id` int(10) NOT NULL default '0', `quiz_question` text NOT NULL, `quiz_answer` text NOT NULL)
ALTER TABLE phpbb_sessions ADD `session_quiz_categories` VARCHAR( 255 ) NOT NULL;
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_show_answers', '1')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Register_Play', '1')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Post_Count_Play', '1')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Post_Requirement', '1')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Play_Once', '1')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Author_Play', '1')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Min_Max_Questions', '5,10')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Author_Mod', '1')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Banned', '')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Moderators', '')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Stats_Display', '10')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Mod_Submit', '1')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Cash_Currency', 'user_points')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Cash_Incorrect', '1')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Cash_Correct', '1')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Cash_Tax', '2')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_CashMOD_On', '1')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_packs_category', '1')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_packs_bot', 'Quartz')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_timeout', '10')
I did all the manual updating first, and was updating form a previous version....
Please help :)
How many of them were red?
VMars
battye wrote:How many of them were red?
all except the last 4
If you were upgrading from 1.2.0 -> 1.3.x, that that is normal behaviour as those rows already exist.
VMars
The problem is that i cant view the quizes that are created (yet they show up in the quiz statitics and they can be played).
Also no points are added to people for correct answers.
here is the main quiz screen:
and here in the quiz statistics it shows the quiz that isn't listed in the other:
Have you got the Cash MOD installed?
VMars
Yeah, and it is running fine.....
I have no idea what the issue is?
